Old 14th August 2004, 10:54 PM   #1
Tim__x is offline Tim__x  Canada
Question 6*lm3886 Bpa
Here's my idea.
  • Bridged Parallel, 3 IC's an arm. (based on the BPA-200 in the app note)
  • Driving a 4 ohm load. Each arm seeing a 2 ohm load, each IC seeing a 6 ohm load.
  • Running on 30+30 volt rails (unregulated)
  • With DC servo's running on 15+15 volts regulated that will also power the input buffers
  • Each LM3886 running in inverted configuration. (one inverting buffer, one non-inverting)
My math is as follows.
30v+30v=60v
60v-6v(for output dropout) = 54v
54v/4ohms=13.5amps
13.5amps/3ic's=4.5amps peak per IC. Seems reasonable to me, what do you guys think?
4.5amps(peak per IC)/1.414 ~3.2amps RMS per IC
I haven't done any power dissipation calculations yet, but with 30+30 rails and a 6ohm load I imagine they'll work fine.
Is this doable?
If so, should I make one big PCB or perhaps design one small pcb with just a single LM3886 and a servo on it and make six of them? Either way I'll make the input buffers on a seperate board.
Edit: With a bridged amp is it necessary to connect the main supply caps to ground or just across the rails?
Old 15th August 2004, 05:45 AM   #2
Send a message via AIM to Mattyo5
BPA-300 :-D Pcb designed!
-Matthew K. Olson
My First LM3886 GC samsagaz Chip Amps 49 29th June 2008 08:55 PM
Psu Lm3886 Mayday Chip Amps 29 29th April 2007 07:10 PM
Lm3886 Bpa Tombson Chip Amps 99 21st August 2006 01:04 PM
Are two separate lm3886 = 2*lm3886 in parallel or bridge mode rs1026 Chip Amps 11 21st October 2004 11:24 AM
Page generated in 0.06034 seconds (74.91% PHP - 25.09% MySQL) with 10 queries
