Old 14th August 2004, 06:23 PM   #1
rs1026 is offline rs1026  India
Angry Blew my transformer
Hi folks,
I was trying to build a amp based on stk 4192 II chip. Since 4192 accepts 8ohm loads.I connected two 4ohm full range speakers in series just to test the amp.
As soon as I turned the power the transformer went to smokes!!
But I could hear some music for 20sec or so. It sounded horrible. It was more noise than music.!
I used a 20-0-20,5amps rating transformer. I think it could not deliver sufficeint current hence got burnt out.
Any ideas what could be the reason and possible solutions.
Somehow I am not very sure of stk 4192's capability. Data sheet looks fine but I havent met anyone who tried using 4192.
Any suggestions??
Thanks,
Old 14th August 2004, 07:02 PM   #2
djQUAN is offline djQUAN  Philippines
Send a message via MSN to djQUAN Send a message via Yahoo to djQUAN
probably oscillation or motorboating.
Old 14th August 2004, 07:56 PM   #3
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
Default Re: Blew my transformer
Originally posted by rs1026
Hi folks,
Any suggestions??
Thanks,
It is almost impossible to blow a transformer by overloading an amp. It really, really is extremely unlikely. Most probably there was either a problem with the transformer wiring or the rectifier (or the amp), in such a way that there was a dead short across the secondaries.
I would suggest to take out the transformer and see if it really is blown. 20 secs or so is not enough to blow a transformer, which can only be blown by thermal overload (and high-voltage overload, but that will not be the case here). And transformers have BIG thermal capacity. Take the naked transformer, separate out the wires to be sure there are no shorts, and apply mains (to the right terminals!) and measure the AC secondary voltage. Chances are it is OK. Then of course the real fun starts....
Jan Didden
/Another new issue: Linear Audio Volume 3!
Old 14th August 2004, 07:59 PM   #4
sss is offline sss  Israel
sss's Avatar
Send a message via ICQ to sss
probably the bridge diodes are blown
Old 15th August 2004, 07:29 PM   #5
Franz G is offline Franz G  Switzerland
Franz G's Avatar
Could you show us your psu schematics please and how you connected the trafo?
Franz
Old 15th August 2004, 10:06 PM   #6
karma is offline karma  Canada
karma's Avatar
i second that
Old 16th August 2004, 12:03 AM   #7
Banned
If you messed up the PSU connections to the chip, that is, you invert + with -, you may kill the trafo in seconds.
That's why you should always use a fuse in the primary, with the correct value.
The fuse would blow before the trafo.
Old 16th August 2004, 06:49 AM   #8
janneman's Avatar
Beg to differ Carlos, you CANNOT blow a transformer in seconds. No way. Even a dead short on the secondaries (which as about as bad as it can get) will not do that. It takes time.
Jan Didden
Old 16th August 2004, 06:59 AM   #9
PMA is offline PMA  Europe
PMA's Avatar
How about rated primary voltage of the transformer, does it fit to your local distribution network voltage?
Old 16th August 2004, 08:32 AM   #10
Jean is offline Jean  United States
Jean's Avatar
Send a message via AIM to Jean
Jan Didden
What he said
left lane is for passing, slower traffic keep right please.
I think I blew up my t-amp...... help! tyler477 Class D 11 27th November 2008 12:34 AM
Fuse blew markiemrboo Chip Amps 30 21st November 2006 04:40 PM
blew up a UCD400. Why did it die? mp006ltk Class D 11 14th July 2006 09:46 PM
My tek 2235A just blew up the PSU cap pukka Parts 15 14th October 2004 12:05 PM
Page generated in 0.09512 seconds (86.93% PHP - 13.07% MySQL) with 10 queries
