Old 14th August 2004, 05:50 PM   #1
Adam M. is offline Adam M.  United States
Default LM3886 Eagle file
Does anyone have an eagle library file for the lm3886 or know an op amp with a compatible pinout in eagle? I found a thread that said there to use a compatible chip or draw it, but I just tried to draw it and got confused. I just tried wiring the amp up P2P and the thing doesn't do anything... no output, no oscilliations, but there are the proper rail voltages on the proper pins, 0V in the correct place, etc.
Long story short, I want to be able to KNOW my solder joints are good, which I can do with a pcb. I'd like to draw it up myself in eagle for the learning experience though.
thanks.
Old 14th August 2004, 06:25 PM   #2
stex is offline stex  Serbia
Default Eagle
Somewhere in this forum I send .zip files with pcb, schematics and library for Eagle. Try to find that.
Old 15th August 2004, 02:15 AM   #3
I'll check but there is a section in eagle with a to220 chip layout that fits nationals designs.
I never figured out how to use custom libraries, anybody want to help?
Old 15th August 2004, 02:16 AM   #4
Default Thanks!
THanks, I did find your files. In the process of drawing the schematic in eagle, I found my mistake. It turns out I thought it would be a good idea to tie the mute pin to ground instead of -Vin. Oops. Amazing how much frustration was caused by soemthing so small. Aah, now its time to battle DC offset and grounding issues... (I have this thing on a breadboard with 11 wires soldered to the lm3886 pins plugged into a breadboard. Man the output is ugly, but the dumb thing works.
BPA300 Eagle File .BRD - No Catches DJ Exprice Chip Amps 414 12th July 2007 03:46 AM
LM3886 PCB gerber file yusuf Chip Amps 0 1st February 2007 03:22 PM
lm3886 library for eagle demons_wing Chip Amps 2 21st August 2004 07:35 PM
LM4780 .lbr file for Eagle Alcaid Parts 2 26th March 2004 06:22 AM
Page generated in 0.07584 seconds (64.34% PHP - 35.66% MySQL) with 10 queries
