| Chip Amps Amplifiers based on integrated circuits |
finished at last. 16volts with secondarys. for briansgt's gainclone
look good? even at 16v the gainclone has lots of power. and sounds a little bit smoother. and without that pop when u turn it on i used cat5 cable 2 wires per rail tested it and its safe even when u short it. wires dont heat up. front
#2 |
back and i forgot the transformer is only 56.2va and after a few hours it stays cool to the touch.
back is still wet
#3 |
Banned
Quite
.But you can call it... Power Ungry.
#4 | |
#5 |
wasnt the original or first gaincard 12v? i have used 25v and 30v
with this amp and i find it sounds better with 16v. ahh i likely need another thanks guys
#6 | |
Banned
The fist Gaincard had (has) 25w, uses the LM1875, and with this (claimed) power and this chip it doesn't work at 16v for sure. |
#7 | |
I also used similar wiring for my amp. When running the amp flat out into a load resistor, I measured a 10mV voltage drop across the the cat 5 cable pair. - Certainly nothing to be concerned about! SteveM |
#8 | |
hehehe i was just playing the real rail voltage from the humpty is 22.1v but it would be nice if it could
#9 |
Carlos,
Are you sure the original 25 watt Gainclone uses the LM1875? At 25 watts, it would seem to make sense. The 50 watt Gainclone then uses the LM3875? I'm uncertain because I was told by Yoshi Segoshi that the newer Shigaraki amp uses a different chip from the original 4707 Gaincard, and that this different chip is one that sounds smoother and more listenable. Turns out that it was the LM1875 in the Shigaraki. Of course, I don't know if he was referring to the the 50 or 25 watt of the Gaincard in this comparison, but I always thought the original used the LM3875. KT |
#10 |
Original Gainclone might be misleading...
I thought the original amplifier called the Gaincard existed in two flavours namely 25 W and 50 W both using the LM3875. The difference was power supply voltage. Later came the Shigaraki which indeed uses LM1875.
UrSv Those who say it can't be done should not stop those who are doing it. |
| gainclone humpty chassis | neil_kaye | Chip Amps | 11 | 2nd January 2006 09:00 PM |
| I got this schematic of a power amp, would like comments | pat allen | Solid State | 37 | 30th December 2004 02:20 PM |
| peters power humpty kinda | karma | Everything Else | 5 | 14th June 2004 01:10 AM |
| Page generated in 0.10784 seconds (74.38% PHP - 25.62% MySQL) with 12 queries |
