kill sound with power off
Hi-
I'm using LM3875 for my amp. I have lots of caps on the power rails (something on the order of 7000uF total). I want to create a mute circuit such that when the power is cut, the sound is too. I don't want the caps to drain power to the chip for 10 seconds after I cut power. For a power supply, I have a regulated ladder supply with 2 voltages per rail. ie +32V and +15V, and -32V and -15V. The 15V rails are regulated with input coming from 32V output. Does anyone have any suggestions as to how to create a mute circuit for this situation? I was thinking about throwing a diode from output of regulator to input of regulator, but because there are two voltages (and two regulators), I wasn't sure if this would work. Any help is appreciated. Thanks,
Doovieman
digi01 said:
I think you may do a simple relay module ;)
this circuit can delay the sound when turn on and turn off the amp.
another,you can add a couple of 'drain resistors(10k-20k)' parallel with the power caps on the +/- rails.that may avoid the caps to power to the chip.
sorry my english:)
digi
Hi digi-
Thanks for the post. That looks like a good solution. Do you have any relays that you reccomend off the top of your head? Ideally pcb mount... Thanks for your time,
Doovieman
