Old 12th August 2004, 01:28 AM   #1
Adam M. is offline Adam M.  United States
Question Finally building... Power supply question
I am finally getting around to building my amp thanks to the help of everyone here, and am at a stopping point on the power supply. How does one wire one of the parts express Avel transformers to get +- dc voltage? Using a bridge on each secondary, I can now get + voltage and ground out of each secondary, but the voltage is positive on both. I was looking at a schematic from SL's website: http://web.archive.org/web/200106191...cs/3886pwr.gif
and it seems that 2 of the 4 wires on the output must be tied together to get the ground... which doesn't seem right to me...
I would welcome any suggestions.
THanks,
Adam
Old 12th August 2004, 01:42 AM   #2
http://www.diyaudio.com/forums/showt...264#post359264
don't thank me...
Thank Brian.
Old 12th August 2004, 02:04 AM   #3
Wow, was that buried in that thread. I got the primaries wired in parallel, its the secondaries getting connected to the bridge(s) that have me confused...
Old 13th August 2004, 01:07 AM   #4
Default Moving forward slightly...
I figured out how to get the +- rail voltage, and what I presume is a ground. I am taking ground to be the connection between the 2 secondaries, which gives me proper rail voltage, and possibly a PS ground. But, when I measure the voltage at that point relative to the ground prong on a nearby plug, I see 25VAC. Is this an accurate ground?
Old 13th August 2004, 03:01 AM   #5
NO NO NO
There is nothing like a ground on that transformer. The only ground (until after the rectifier board!) will be the third wire of the AC supply coming begore the transformer. Black~ hot, White~neutral, Green~ground.
Old 13th August 2004, 03:02 AM   #6
...and that green wire goes to the enclosure (chassis).
Old 13th August 2004, 03:35 AM   #7
Where would I draw the ground from after the rectifier board? Right now I have the primaries in parallel, the secondaries in series, with the input to the bridge coming from the other 2 ends of the secondaries, which gives me +-35v relative to the middle of the transformer. How do I wire the thing to get +-35v relative to ground (a real ground this time) instead? Thanks for the help.
Old 13th August 2004, 01:40 PM   #8
After the AC supply ground goes to case, then that's the only real ground from this point on. You will tie all other grounds to the "star ground".
see grounding
additionally for a graphic rep...
more
Old 13th August 2004, 08:42 PM   #9
Default negative rail voltage
Where do I pull the negative rail voltage from? I can only get -rail relative to the middle of the 2 secondaries, not relative to a real ground. I have tried with both 1 and 2 bridges, and can't visualize what needs to happen to get the -rail. Any suggestions?
need help in building 24v power supply milen007 Parts 10 11th September 2008 05:11 AM
Building Power supply for AA DAC regal Digital Source 4 21st May 2007 08:01 PM
Building power supply for master clock questions KevinLee Digital Source 15 31st March 2004 12:38 PM
Building a power supply unit. S.C Chip Amps 4 6th August 2003 08:59 PM
Having trouble building a power supply for a phono preamp SideA Solid State 1 4th April 2003 06:34 AM
Page generated in 0.10272 seconds (74.18% PHP - 25.82% MySQL) with 10 queries
