Old 11th August 2004, 03:07 AM   #1
Default LM3886 amplifier problem
I was building an LM3886 amplifier (mono) for driving a subwoofer.
well, i used a schematic that I found here, and I changed it from inverting to non-inverting.
I got about +/-35VDC for the supplies, and I built the amp.
This particular schematic didnt have a output coupling capacitor, and I checked the output for DC, and I have a full 35vdc on the output. Something is wrong.
is there supposed to be an output coupler cap? Whats it for.
UPDATE: I tried to use a coupling cap, no difference. ALL DC.
anyway, I put the scale over to AC, and the audio is getting through and being amplified. just got tons of DC.
Any idea why this may be happining.
Old 11th August 2004, 03:57 AM   #2
meat is offline meat  United States
I had the same problem the other day and it turned out that my feedback resistor was soldered to the wrong pin of my chip, so I had an open loop. That's probably not it, but you never know. You could also have some sort of a grounding issue.
Old 11th August 2004, 04:06 AM   #3
the schematic I have called for a 1meg feedback resistor.
i doublechecked the wiring, and its not messed up.
Old 11th August 2004, 04:24 AM   #4
oops. hehe. I found my problem. The search button is good for these kinda things DOH!
anyway, the problem was since im using non-inverting, I needed a resistor from the input to ground. Well, I didnt have that.
I put a 10k there, and my DC offset is just below 2mv
Old 11th August 2004, 04:58 PM   #5
CRAP!!!!
I went to hook it up today, its no sound, all hum. its a low level hum, but its enough for my speaker to pop all the way out.
I need help!!!
Old 11th August 2004, 05:03 PM   #6
Netlist is offline Netlist  Belgium
Netlist's Avatar
Hi Mbates14
Hum, speaker popping out?
Sounds like DC again.
What schematic are you using? Any link?
Don't worry, we'll get you out of the mess
/Hugo
Old 11th August 2004, 05:35 PM   #7
I used this schematic and tried to make it non inverting.
basically, I took in the schematic, pins 9 and 10 and switched them, leaving the feedback loop on -, and putting another 22k resistor from + to ground for non inverting.
Old 11th August 2004, 07:12 PM   #8
jee. i need to have a little more patients in what im doing.
Well, after scowering and scowering the circuit, OOPS! the 100uf cap on the mute pin8 was backwards. oops. I put that in the right way, and then for the hell of it, i made it back to inverting, and bingo. It works. no DC, and the sound pounds.
Old 11th August 2004, 07:17 PM   #9
Netlist's Avatar
Glad you found it.
Two things come to mind:
1) I would put a new cap in there.
2) The cap won't have been the cause of the problem IMHO.
/Hugo
Old 11th August 2004, 08:42 PM   #10
OMG 1 chip starts an earthquake, I wonder what 2 or 3 would do parallel. Blow the roof off?
im scared to see what you guys have done with 5 or 10 chips a channel
LM3886 Stereo Amplifier problem Razbi Chip Amps 8 10th October 2006 01:01 PM
LM3886 problem, HELP! Matthewong Chip Amps 36 7th February 2006 05:00 PM
LM3886 problem skyraider Chip Amps 15 20th January 2004 08:49 AM
LM3886 problem skyraider Solid State 11 20th January 2004 07:17 AM
Page generated in 0.11244 seconds (70.30% PHP - 29.70% MySQL) with 11 queries
