| Chip Amps Amplifiers based on integrated circuits |
I'm building my first gainclone using a wooden chassis (sorry no pics yet) and 2x12v Sealed Lead Acid batteries wired in series. For power supply stability I'll be using 10uf film caps. Is it ideal to have a seperate power supply filter caps ground point and another seperate ground point for the negative binding posts and rca input ground? Should each channels ground points be done in a 'dual mono' fashion? Both channels will be run from a single 24v battery. I don't intend on connecting the ground to earth unless anyone see's good reason to.
Brian |
| Battery powered XO? | MikeHunt79 | Solid State | 2 | 17th March 2008 02:19 AM |
| Battery powered amp | Shpoop | Chip Amps | 8 | 26th January 2007 03:41 PM |
| battery powered gc in a tin | digi01 | Chip Amps | 11 | 25th December 2004 04:11 AM |
| Newbie wants to build a "GainClone-Like" 5.1 Channel Battery Powered Amplifier | captain | Chip Amps | 7 | 15th October 2004 12:35 PM |
| How much power will a battery powered GainClone produce? | Tony D. | Chip Amps | 2 | 5th July 2004 09:20 PM |
| Page generated in 0.06942 seconds (73.90% PHP - 26.10% MySQL) with 10 queries |
