GainClones & 4 Ohm Loads
Old 9th August 2004, 08:39 PM   #1
SRMcGee is offline SRMcGee  United States
SRMcGee's Avatar
Default GainClones & 4 Ohm Loads
Folks:
Has anyone tried their GainClone out with a difficult speaker? I am building four BrianGT-based GainClones with a friend, and he is interested in pairing one of his with a pair of Thiel speakers (the 2.6, I think), which has 4 ohms impedence.
Is anything likely to blow up? Will GainClones acquit themselves with honor under a tough load? Will the Thiels' sound be adversely affected? All knowledgable responses are appreciated.
Thanks,
Scott
Old 9th August 2004, 11:04 PM   #2
chipco3434 is offline chipco3434  United States
I am running PE/Pioneer 4"/Dayton tweet DIY line arrays with gain clones... one intergrated the other not. The speakers are about 5 ohm nominal.
I can run it until my ears bleed but them amp never complains... the CD will skip, but the amp doesn't fuss.
Anyway, the internal (SPIKE... TI trademark) will protect the chip from most stupid stuff.
Old 9th August 2004, 11:13 PM   #3
usekgb is offline usekgb  United States
usekgb's Avatar
The ideal way to run a gainclone in to a 4 ohm load is to use the paralled configuration. You can do this with two of BrianGT's boards if you wish. Run the signal input to both gainclone inputs (or use an input buffer if you wish), and put a 1% (even better, use a 0.1%) 0.1 ohm 5 watt resistor on the output of each chip amp. Tie these two outputs together, and you have a gainclone that can deliver twice the current of a single chip version. This will easily push your 4 ohm load.
Zach
Ahhhhhhhhh...............That's what that button does.
Old 9th August 2004, 11:29 PM   #4
BrianGT is offline BrianGT  United States
diyAudio Moderator Emeritus
BrianGT's Avatar
Send a message via AIM to BrianGT
I use my gainclone with my 4 ohm Seas Thor TL speakers, and I have had no problems. I am using a 320va 2x24vac transformer, and I can turn it up all the way without problems. This creates volume levels that are too loud to listen to.
I would recommend trying the standard configuration first. As for the 2x24vac voltage, it seems to work fine for me. It seems that the datasheet is conservative in their voltage ratings.
Brian
Old 9th August 2004, 11:30 PM   #5
kestrel200 is offline kestrel200  United States
Use a transformer rated at 18V & you'll be fine. I used a 22V and power an MTM rated at 4ohm at very loud levels and the sides of the case get pretty hot but the amp still doean't clip. But an 18V would be better according to the spec sheets.
Old 9th August 2004, 11:56 PM   #6
carlosfm is offline carlosfm  Portugal
Banned
Default Re: GainClones & 4 Ohm Loads
It's not just a question of manufacturer's rated impedance.
Most modern speakers (the trend is bass-reflex) have impedance dips in the bass region and 4 ohm speakers can go lower in some frequencies.
You don't know until you try the amp with those speakers.
My guess is that it won't drive them, no way.
The typical GC can't drive properly a pair of B&W 602 S3, and they are rated 8 ohms! But they have impedance dips to less than 3 ohms.
Rest assured that not every commercial amp can drive them anyway, you need a good one.
Some people don't notice when the amp is not driving their speakers properly.
They simply don't mind to have their house shaking with untight bass, some guys like it!
No problem for the amp.
But it will sound bad, because bad bass spoils everything, including midband and treble.
You can parallel two chips per channel, and maby then the amp will behave with those speakers.
You need a big trafo or one per channel.
GainClones & 4 Ohm LoadsHide this!Advertise here!
Chokes loads hugobors Solid State 0 2nd March 2005 10:01 PM
Choke loads for SOZ Magura Pass Labs 34 17th November 2004 04:29 PM
Now what, each page loads twice. Bill Fitzpatrick Forum Problems 3 11th September 2004 09:16 AM
using 2 ohm loads on leach amp Wagener Solid State 4 1st April 2004 07:02 AM
Need something stable into <8 ohm loads Jean Solid State 7 25th September 2003 11:05 AM
Copyright ©1999-2017 diyAudio
