Old 8th August 2004, 09:45 AM   #1
Default Opa541-548-549
Hi guys, one of my friends have send me over some OPA541, OPA548 and OPA549 dozen each andI though I might wanna build some sub amps with em.
Heres what I want to do:
1) A sub amp for car using OPA548 in single supply mode a parallel application may be:
2) A sub amp for home use using OPA549 dual supply mode a parallel application.
3) Rest of the chips to be used as satellites and front speaker.
Does any one have made such applications, I ll appreciate if anyone posts his schematics here I ll make the layouts myself.
Thanking in Advance.
Old 8th August 2004, 10:12 AM   #2
kinser is offline kinser  Israel
kinser's Avatar
Send a message via ICQ to kinser Send a message via MSN to kinser
Abdir,
I found this web site on google image search and found some schematics for the OPA541
I hope this helps you:
http://www.freewebs.com/matttcatttweb/audio.htm
Kinser
Old 8th August 2004, 02:51 PM   #3
Default Re:
Kinser Thanks, website is of help as far as building a sub using OPA541 in dual supply mode, now for the second part where I wanna build sub for car using OPA548 in single supply parralel mode, I look forward to "DIYers" for help.
Also any suggestions building sub using OPA549 parallel mode having OPamp filters third order maybe at the input stage will be welcome.
Rehan
Old 9th August 2004, 07:06 AM   #4
read the app notes at www.national.com
search for lm3886 and look at the high power apps. most of the advice still applies.
when using 2 ICs, you should take steps to match the outputs -- gain and dc offset. for a single supply this shouldn't be hard -- tie the amps together after the output caps. i'd still run a 0.1 or 0.2 ohm resistor in series with the output to prevent one IC from suppling more current.
if only it could be used for good, not evil...
Opa541 - Bpa-200 kinser Chip Amps 5 11th September 2005 08:43 PM
help me with OPA541 Oxujens Chip Amps 9 7th April 2005 07:33 PM
opa541 sss Chip Amps 3 6th August 2004 10:27 AM
My very own OPA541 GC MikeF777 Chip Amps 4 9th December 2003 05:24 PM
opa541 pundip Solid State 5 2nd March 2003 06:08 PM
Page generated in 0.09990 seconds (64.08% PHP - 35.92% MySQL) with 10 queries
