Old 6th August 2004, 03:14 PM   #1
lawbadman's Avatar
Default Tda8567
Hey Guys, I just have a simple question.
I want to make a high power car amp but I want to avoid making a smps. I am thinking of using a TDA8567 or a similar BTL chip amp. From experience I know that these chips run out of power real quick.
The question is, can I parallel two or more outputs to get more power?
I would connect positive outputs via a resistor (about 0.1 ohm), and the same for the negatives.
Would this work?
Here is the datasheet: http://www.semiconductors.philips.com/pip/TDA8567.html
Lawrence
Old 6th August 2004, 03:24 PM   #2
Banned
What about the TDA1562?
Old 6th August 2004, 03:44 PM   #3
lawbadman's Avatar
I'm not a big fan of the TDA1562
Correct me if i'm wrong but it only produces 70w for a short period of time which is the extra power from the 4700uf capacitors. When the caps have discharged the power goes down to about 20 watts.
Page generated in 0.06267 seconds (71.21% PHP - 28.79% MySQL) with 9 queries
