Old 6th August 2004, 09:14 AM   #1
sss is offline sss  Israel
sss's Avatar
Send a message via ICQ to sss
Default opa541
hello eveerybody
guys i wanna know if bridged opa541 can handle 8ohm speaker (not paralelled ) with max voltage supply (+-40V) without overheating
also
i read the whole datasheets and found nothing about thermal protection , so i guess there is no thermal protection , right?
Old 6th August 2004, 09:33 AM   #2
Banned
Never use max. voltage on a power op-amp.
It will overheat.
Does true 8 ohm speakers still exist?
Speakers always have impedance dips across the range, some 8 ohm speakers can have impedance dips to as low as 3 ohms, usually in the bass, and specially bass-refex speakers.
I would use the 541 at +/- 30~32v, no more.
With two chips, I would prefer to parallel than bridge them.
Or bridge-parallel, but that's 4 chips per channel minimum.
Old 6th August 2004, 10:23 AM   #3
sss's Avatar
thanx for the reply Carlos
i guess its better to use the opa549 with ~28V supplies
Old 6th August 2004, 10:27 AM   #4
Hi
Oh minimum 4 chips per channel.
I cannot build the high watts amplifier because my loudspeakers are just 100W
Opa541 - Bpa-200 kinser Chip Amps 5 11th September 2005 08:43 PM
help me with OPA541 Oxujens Chip Amps 9 7th April 2005 07:33 PM
Opa541-548-549 abid_rehan Chip Amps 3 9th August 2004 07:06 AM
My very own OPA541 GC MikeF777 Chip Amps 4 9th December 2003 05:24 PM
opa541 pundip Solid State 5 2nd March 2003 06:08 PM
Page generated in 0.06753 seconds (73.41% PHP - 26.59% MySQL) with 10 queries
