| Chip Amps Amplifiers based on integrated circuits |
Folks:
I will be building four integrated GainClone amps, and have ordered four Premium GainClone kits from BrianGT. I would like for one of the integrated amps to have two sets of speaker outputs. The idea is to drive only one set of speakers at a time, not both pairs. I know enough to realize that I will need a switch of some kind and another pair of speaker terminals. The switch will be mounted on the front of the chassis, and I don't want to run the outputs from Brian's PCBs from the rear of the chassis to the switch and then back to the speaker terminals on the rear. So what do I do to keep the signal-carrying wiring to a minimum? Is there a simple way to drive a relay (or relays) to control which speaker terminals are "live"? Do relays add coloration or noise (including buzzing)? Any advice or direction you can offer would be appreciated. Thank you, Scott |
#2 |
Why not with switch? you just have to swithc the hot as the out grounds will be common ground, one DPDT switch, and if you are concerned about stray coupling use shielded coax 3 sets of wires,
ground shield in one place only.
Sheldon D |
#3 |
or use rotary switch with extender to back of chassis
Sheldon D |
#4 |
u could try some relays or something...
Kids in the back seat cause accidents...Accidents in the back seat cause kids... |
| laying out dual output push-pull transformer? | zilog | Power Supplies | 0 | 2nd September 2008 08:50 PM |
| Biggest dual triode output tube? | leadbelly | Tubes / Valves | 3 | 30th July 2007 08:57 PM |
| schematic for dual output synchronous rectifier needed | zilog | Power Supplies | 3 | 27th January 2006 06:32 AM |
| Dual differential mode inductors in a bridged output lowpass filter | BWRX | Class D | 3 | 17th November 2005 03:39 PM |
| Testing a dual output DC/DC converter | Eric J | Parts | 4 | 10th June 2003 05:34 PM |
| Page generated in 0.07909 seconds (73.33% PHP - 26.67% MySQL) with 10 queries |
