Old 3rd August 2004, 03:08 PM   #1
digi01 is offline digi01  China
digi01's Avatar
Send a message via MSN to digi01
Default scratch BPA200 pcb lay out
the PCB lay out is a pretty crazy DIY things for me
this is my BPA200 projects,the chips +/- rail and ground track has not finished yet,any suggestions??
the sch is based on the original BPA200 article,use DC serv.and the amp pcb is not including the push stage.
Old 3rd August 2004, 04:13 PM   #2
Banned
No need to use servos.
Old 4th August 2004, 12:31 AM   #3
digi01's Avatar
mmm...
because those 3886 chips need to leave certain distance.it happens that there is space of serv parts on the boards,I put it.
I think it's wise to provide the board space for serv circuit.If you do not like the BPA200 work at serv mode,just leave the serv chip socket empty.
Old 16th August 2004, 01:12 PM   #4
digi01's Avatar
optmize version,including input buffer.
the pdf file show top and silk layer
Old 25th August 2004, 12:50 AM   #5
digi01's Avatar
My matrix power supply boards,for BPA200.
a couple of typical unregulated bipolar power supply,and big caps of supply reservoir capacitance for each supply voltage rail.
the PCB board can mounting 300/400mil pins,44mm(max) diameter caps.
enjoys
Old 25th August 2004, 12:52 AM   #6
digi01's Avatar
another small design.
Old 25th August 2004, 01:15 PM   #7
digi01's Avatar
ver#1.0 source share.
try upload my BPA200 gerber files.can anybody give me a rank
enjoys
Old 25th August 2004, 05:02 PM   #8
Mad_K is offline Mad_K  Norway
Mad_K's Avatar
Do you not have ANY psu decoupling caps on the mainboard?
Mads K
Old 26th August 2004, 01:46 AM   #9
digi01's Avatar
The main board was not set up any bypass caps.I have leave a series holes near the chips for mounting the mother rails of power supply.
Old 15th February 2005, 09:25 PM   #10
troystg is offline troystg  United States
troystg's Avatar
enjoys
Hey digi01-
Will you be offering these boards for sale too?
I have the perfect chassis for a pair!
Troy
Thinking positive doesn't make things better, it makes you a better person.
Max voltage for bpa200 enter Chip Amps 29 18th February 2006 11:54 PM
Bpa200 enter Chip Amps 2 3rd January 2006 08:16 PM
BPA200 PCB design nterikun Chip Amps 1 13th September 2005 09:39 PM
BPA200 PCB Layout nterikun Chip Amps 12 13th September 2005 12:51 PM
My BPA200 PCB Dxvideo Chip Amps 14 11th December 2003 07:25 AM
Page generated in 0.10459 seconds (75.83% PHP - 24.17% MySQL) with 11 queries
