Old 28th May 2005, 09:31 PM   #71
Are all the resistors 1% or .1%?. I didnt bother with the .1ohm output resistors. I used .22ohm.
The only time I got 150mv is when I didnt ground the input properly.
You should email Jackinnj. He has more experience with the lm4780 chip?
Old 2nd June 2005, 07:40 AM   #72
Dear All,
Please see the attachment !
Can I reduce the cost by don't put the "Input Cap" for each LM3886 ?
Thanks !
Thomas
Old 2nd June 2005, 08:14 AM   #73
Don't make it with DRV 134 - it's not quite good sounding circuit .
Old 2nd June 2005, 10:29 AM   #74
The lm3886 needs a gain of aleast 10. If you want to use a gain of four use the OPA chips (549 or 541). The OPA chips cost 3 times as much as lm3886. You can leave out the input caps,but you might have a problem with dc offset.
Old 2nd June 2005, 01:28 PM   #75
macboy is offline macboy  Canada
Nice catch. It's no wonder that the amp is oscillating. Do people even bother to read datasheets anymore?
Old 2nd June 2005, 04:11 PM   #76
troystg is offline troystg  United States
troystg's Avatar
Pavel-
So what do you suggest as a replacement?
Troy
Thinking positive doesn't make things better, it makes you a better person.
Old 4th June 2005, 02:06 AM   #77
mateo88 is offline mateo88  United States
Is it even neccessary to use the DRV134 or a similar chip at the input?
i.e., can you just take two of image 5.2.1 in the AN-1192 datasheet and parallel them?
Old 4th June 2005, 06:10 AM   #78
Two bridged amp in parallel would still require output resistors. Image 7.2.4 would be better.
Old 4th June 2005, 01:00 PM   #79
Yes, I know it would still require output resistors. I guess my real question is in figure 7.2.4, why is U5 needed?
Old 4th June 2005, 03:22 PM   #80
U1 is used to isolate the source from the chips low impedance input. The input without the buffer, would be less than or around 500ohms. Input impedance plays a role in frequecy response.
My First LM3886 GC samsagaz Chip Amps 49 29th June 2008 07:55 PM
Psu Lm3886 Mayday Chip Amps 29 29th April 2007 06:10 PM
Are two separate lm3886 = 2*lm3886 in parallel or bridge mode rs1026 Chip Amps 11 21st October 2004 10:24 AM
6*lm3886 Bpa Tim__x Chip Amps 1 15th August 2004 04:45 AM
Page generated in 0.14799 seconds (62.29% PHP - 37.71% MySQL) with 11 queries
