| Chip Amps Amplifiers based on integrated circuits |
#21 | |
Many thanks ! Thomas |
#22 |
Here a schematic
#23 |
The trimmer value should be the same as feedback resistor in this case 470k. If you cant find a 470k trimmer,500k will do.
#24 |
Thank You For Your Post !
Do you think the Rowland M12 is use invert connection for all LM3886 and use DRV134 at the front ? Thomas |
#25 |
Your welcome
I dont know about the M12 but if it has the lm3886 and a trimmer more than like it's inverted. I do know that the concentra is inverted and uses the drv134. I think M12 uses more lm3886 and is monoblock. |
#26 |
Here a picture of my ver.
#27 |
wired up
#28 |
Dc offset
#29 | |
How do you calculate the feedback R (470k/16k) in your ver. ? As shown in BPA 200 document, thet are (21.5K/1K). Thanks ! Thomas |
#30 |
Your welcome
I dont know if concentra uses buffer in front of drv134. I have the gain 13 on the (+) side and 13 on the (-) that adds up the 26. The example I post was just an example. If you use bridged parallel, you must use a lower gain than normal because both side adds up. |
| My First LM3886 GC | samsagaz | Chip Amps | 49 | 29th June 2008 08:55 PM |
| Psu Lm3886 | Mayday | Chip Amps | 29 | 29th April 2007 07:10 PM |
| Are two separate lm3886 = 2*lm3886 in parallel or bridge mode | rs1026 | Chip Amps | 11 | 21st October 2004 11:24 AM |
| 6*lm3886 Bpa | Tim__x | Chip Amps | 1 | 15th August 2004 05:45 AM |
| Page generated in 0.11010 seconds (72.34% PHP - 27.66% MySQL) with 11 queries |
