Old 5th July 2005, 03:02 PM   #91
Originally posted by thomasfw
Dear Jaudio,
By the way, I have just made a tube buffer for my friend.
It connect in between DVD player (Made in China, HKD499) and
a AV amp.
You can't belive how great it is !!!!!!
Thomas
Ok I cant resist. Can you Email the schematics to me?
Old 5th July 2005, 03:19 PM   #92
Dear Jaudio,
How can I get your e-mail ?
Thomas
Old 5th July 2005, 04:30 PM   #93
In the upper left hand column of each post there is an authors name: click the name
Old 12th July 2005, 06:41 PM   #94
jkraxi is offline jkraxi  Romania
Send a message via Yahoo to jkraxi
please help me. I desperately need a schematic of JR model 12-concentra.
pls.mail me at jkraxi@yahoo.com
thx, JAY
Old 18th August 2006, 01:38 PM   #95
Mrpong is offline Mrpong  Thailand
Originally posted by jaudio
No buffer needed.
The caps go bewteen drv134 output and input resistor of each lm3886. Be sure to match all resistor as close as possible
Hi JAUDIO,
For the circuit you shown in #62, can I replace the 10uf cap with 1uf? I think the purpose of 10uf is to block DC. Correct?
Old 18th August 2006, 03:34 PM   #96
HI
That cap also act as part of a high pass filter. If you use a 1uf cap with the same resistor value then the cutoff frequency will be
159155/(R*frequency)=C(Capacitor value)
for a 20hz cutoff frequency,you should divend by 4.
5Hz would be your target
Old 19th August 2006, 11:51 AM   #97
HI
Thank a lot JAUDIO, I think I may misunderstand something
With R=3900, C=1uF, this equation would give
the cutoff freq = 159155/(3900x0.000001) Hz????????
Old 19th August 2006, 01:02 PM   #98
Hello
For a 1uf cap and a resistor value of 3.9k, the cutoff frequency is 40Hz, which is much too high.
Let say you want a cutoff frequency of 15hz
1. 15Hz/4=3.75Hz
2. 159155/(3900*3.75)=11.3uf
R is the resistor on the inverted input
Remember,I used 3.9k on the schematic
for an example,your value may be different.
Old 21st August 2006, 08:31 AM   #99
According to this original BPA200 schematic, I think we can use trimpots at the + input PINs of U3 and U4. However how can we use trimpot at U1 and U2?
Old 21st August 2006, 01:04 PM   #100
Add trimpots the U1 and U2 wont work, the impedance in the chip is too high.
In the schematic, I posted all the chips are in the inverted mode.
If you use the original BPA200 schematic, you won’t be able to adjust the dc offset. There are a few things you can do to minimize the offset
Increase the output resistor value to .3 to.5 ohms
Use chips with similar dc offset (You will have to buy more chips to match them)
servo s
You should use the original Bpa200 schematic or the schematic I posted. I don’t think the schematics can be mixed together
My First LM3886 GC samsagaz Chip Amps 49 29th June 2008 08:55 PM
Psu Lm3886 Mayday Chip Amps 29 29th April 2007 07:10 PM
Are two separate lm3886 = 2*lm3886 in parallel or bridge mode rs1026 Chip Amps 11 21st October 2004 11:24 AM
6*lm3886 Bpa Tim__x Chip Amps 1 15th August 2004 05:45 AM
Page generated in 0.11408 seconds (79.76% PHP - 20.24% MySQL) with 11 queries
