| Chip Amps Amplifiers based on integrated circuits |
I am working up the design of an amp thats going to be switchable between bridge/parallel mono and stereo/parallel operation. The AN-1192 bulletin(BPA-200 example) suggests using servos (an integrator)to cancel dc offset.
My question is would it be equally good to put in a precision trimmers and hand trim each output? or does it need to be actively compensated for? Any help would be appreciated. |
#2 |
I built that circuit. I just used a multimeter and used resistors within +-.1% tolerance and had perfect results. Servos are overkill.
#3 |
Overkill, I agree.
Just try to match resistors as close as possible and your fine. JojoD |
#4 |
Trimming and selecting yields a "true DC". DC servo supresses transfer below certain frequency (although it can be low enough) and the complete circuit can have quite long settling time (e.g. after switch-on). But, I don't assume the DC servo to be an overkill - I use it, if the trimming needs to be avoided.
#5 |
Thank you for the responses. I do not understand this response however.
bobolix wrote: Trimming and selecting yields a "true DC". DC servo supresses transfer below certain frequency Does this mean the servo will act as a high pass filter? |
#6 | |
DC should really be called Zero Frequency in this case, because that is what is meant. So the amp will have no gain at zero frequency, it will be attenuated by the servo loop, yet it must have gain at audio frequencies to hear the output. The frequency of transition between the two is determined by the CR network in the servo, usually the servo amp is wired as an integrator or single pole filter. |
| Improving DC-servos | Elvee | Solid State | 22 | 16th September 2008 11:04 AM |
| cascaded servos | Onvinyl | Solid State | 0 | 6th June 2008 05:36 PM |
| Zapfilter DC offset trouble, help needed | Sarman | Digital Source | 35 | 12th February 2007 08:15 PM |
| Help needed: odd DC offset on UCD400. | maxlorenz | Class D | 16 | 8th September 2006 05:08 PM |
| Page generated in 0.07953 seconds (68.26% PHP - 31.74% MySQL) with 10 queries |
