Old 28th July 2004, 03:21 PM   #1
Drioannis's Avatar
Default Sony NS900 OPA2134 or AD8066?
I want to upgrade my DVD-SACD-CD player with better opamps.Do you have any expirience on these opamps.What character in sound do they have?
Old 30th July 2004, 06:28 AM   #2
DIAR is offline DIAR  Finland
DIAR's Avatar
I just ordered one of these for my NS900 (AD8065):
http://www.lcaudio.dk/com/index.php?page=5
Do you know what are the basic differences between AD8065 and 8066?
Old 30th July 2004, 06:59 AM   #3
PMA is offline PMA  Europe
PMA's Avatar
Default Re: Sony NS900 OPA2134 or AD8066?
8065 is single while 8066 is double.
They are great opamps, probably the real top now.
But - they are very very sensitive to capacitive load. So follow the datasheet recommendations and separate every cable, even as short as 10 cm, by resistor in series with opamp output. Direct replacement for older opamps in a socket may bring oscillations.
Old 30th July 2004, 07:49 AM   #4
DIAR's Avatar
Hmm... Knowledge comes with pain...
How about the LCaudio module. Is there something that helps to prevent any oscillation.
The attachment is a picture of the players analog output. Any comment on that. Should I replace some parts when I replace the OPAmp with LCaudio module.
Any help is greatly appreciated !
Edit: My preamp is passive 10 kohms. Any problems to be expected?
http://kotiweb.kotiportti.fi/audiovideo/DIY/preamp1/
Old 30th July 2004, 07:55 AM   #5
DIAR's Avatar
problems with image...
Old 30th July 2004, 09:25 AM   #6
Drioannis's Avatar
I have not yet in my hands the opa2134 and the ad8066 but I hope in a few days to give you some info.
Old 30th July 2004, 09:31 AM   #7
Drioannis's Avatar
What type of ad8066 SOIC8 or ad8066 MSOP8 is for the NS900?I think the first.The 8066 is the dual version of 8065.Normaly the NS900 has dual opamps but the LC made a base and putted 2 8065 in one socket.
Old 30th July 2004, 03:08 PM   #8
DIAR's Avatar
Default LC Audio rules!
The AD8065 that I ordered earlier this week arrived today. The same week! Can't get any faster than that!
The packing was also top notch!
LC Audio - Highly recommended
Let's see if I can install this without smoke.
Edit: I have to gripe about one thing. There was no documentation or manuals included in the delivery
Old 31st July 2004, 03:44 PM   #9
rdf is offline rdf  Canada
rdf's Avatar
Check the DC offset on the IC output, you might also be able to get away with bypassing (short) the 100 uf electrolytic output coupling caps C212 & C214. Cheap electros aren't usually considered 'sonically optimum' devices.
Old 31st July 2004, 08:32 PM   #10
DIAR's Avatar
How is the dc offset measured?
Those caps are Nichicon Fine Gold caps. they should pretty ok, but I'm considering changing them to Black Gate caps. I don't dare to remove the caps completely
Picture of the original OPA and the place where it used to be:
I had to put a holder under the AD8065 to lift it above the caps.
AD8065 at its new home:
http://kotiweb.kotiportti.fi/audiovi...paikallaan.jpg
I have to burn in the new OPA before I say anything about its sound.
AD8066 vs. LM4562 douglesc Parts 21 22nd December 2011 02:41 PM
Ad8066 lduarte1973 Chip Amps 2 13th March 2009 09:10 PM
How would you modify Sony DVP NS900 DIAR Digital Source 42 2nd November 2004 08:13 AM
Ad8066 Tuur Parts 0 13th August 2004 04:41 PM
AD8620 vs. AD8066 Crazy_D Digital Source 3 15th February 2004 07:12 PM
Page generated in 0.10534 seconds (77.61% PHP - 22.39% MySQL) with 11 queries
