| Chip Amps Amplifiers based on integrated circuits |
#11 |
Some will go much higher than that, but none that "we" usually use... It may be spendy to acquire but they are out there.
Jesus loves you. |
#12 | |
Jan Didden
/Another new issue: Linear Audio Volume 3! |
#13 | ||
Sorry for the confusion. |
#14 |
OK, got you. So, the basic issue is this, if I am correct:
What is the best way to built an audio power amp, starting with a lot of LM3886'es and a +/- 75 V supply, right? Jan Didden
#15 | |
Yes and no.
Yes: I have 20 LM3886s and a 75v supply, and I want to build an amp. Now I would ask your question: Quote:
I already have a design (attached), and I'm looking for comments about it. I am using output transistors, because I want the amp to be bridgeable. Putting 150v (+75v and -75v) across the LM3886 is not a good idea. Will this amp work? I did simulations of it, and it turns out ok. Does anyone see any problems with it? Which transistors should I use for the supply and output? The writing on the schematic is small, so for those of you who can't read it, here it is (from left to right): First is the input (signal generator), then an 80 hz low pass filter, then a phase splitter with a gain of 5x, and finally the amps (25x gain). The overall gain of the amp is 125x for single-ended, and 250x for bridged. |
#16 |
By this connection is shifted also DC input voltage on LM's and input of this circuit will be destroy
#17 | |
BTW, I am missing a proper bias set-up to get the output drivers in proper class AB. Now it will unnecessarily suffer from cross over distortion. Cheers
#18 |
Would I get enough phase lag from this setup to cause problems?
How would I go about biasing this output stage? |
#19 | |
I just realized that I don't need to bias the output transistors. The feedback is connected after the output transistors, and the opamp will compensate for the transistor bias. My simulation showed this as well.
This is from a document I found online. If anyone wants it, email me at xplod1236@wowway.com. Quote:
#20 |
Does anyone see any other problems with it?
| No Miller cap, Double bootstrapping amp. | GEirin | Solid State | 41 | 1st December 2007 10:08 AM |
| Active Elevated Rail Hi side Bootstrapping Technique for IR2110 | Workhorse | Class D | 93 | 6th November 2007 08:49 AM |
| Bootstrapping a LM38XX and OPA54X | audioPT | Chip Amps | 2 | 25th February 2005 02:04 PM |
| bootstrapping two SE transformers into a pp one? | Rockmonton | Tubes / Valves | 8 | 16th November 2004 01:10 PM |
| Are two separate lm3886 = 2*lm3886 in parallel or bridge mode | rs1026 | Chip Amps | 11 | 21st October 2004 10:24 AM |
| Page generated in 0.11658 seconds (72.46% PHP - 27.54% MySQL) with 11 queries |
