Old 27th July 2004, 06:44 AM   #1
digi01 is offline digi01  China
digi01's Avatar
Send a message via MSN to digi01
Smile my 3886IGC pcb
Revised repeatedly,optimization...I finished this PCB project at last.Thanks for 1audio, carlmart, jcarr very much.please look at the primitive scratch for more detail
I have set up some 'leap' points on pcb, it is joined that it is convenient to expand.bridge or parallel is easy.
yours
-digi
Old 27th July 2004, 11:34 PM   #2
digi01's Avatar
MUSE and ELNA-bp caps,HOLCO and DALE resistors.
Old 28th July 2004, 03:59 AM   #3
thomas997's Avatar
Looks good.
Now send me some for free
Old 28th July 2004, 06:41 AM   #4
otaku is offline otaku  New Zealand
Looks very nice!! Can I buy some?
Old 28th July 2004, 08:26 AM   #5
digi01's Avatar
something in the PM
for more infor pls mail to vcgft@yahoo.com.cn
Old 28th July 2004, 12:13 PM   #6
Default Re: my 3886IGC pcb
The pcb looks very, very good. Just three things, some mentioned on one previous mail of mine:
1) The tracks to +V and -V should be wider. If the pins are N/C, as the data specifies, you can use that area to make the track wider, on the top or bottom.
2) Provide some area on the bottom to use an SMD output resistor, like the Dale type that Rowland uses.
3) You should bypass the mute pin to ground, like the datasheet specifies. I didn't use it on my first prototype, but it's provided on my revised pcb.
The rest is very good. Congratulations! Is it possible to get some, paying of course?
Carlos
Old 29th July 2004, 01:21 AM   #7
digi01's Avatar
carlmart,thanks for you helpful suggestions again
Pins of LM3886 arranges very inconvenient,when you lay out with fat tracks,those NC pins is really a hellits mute pin and gorund pin let the things become complicated too.
btw,please check you mail
digi
Old 29th July 2004, 02:10 PM   #8
troystg is offline troystg  United States
troystg's Avatar
Hi digi-
"for more infor pls mail to vcgft@yahoo.com.cn"
Is this contact handling a "group buy" or outright sales of these boards?
And the boards look great. Only request I have is for a separate mounting hole on the supply capacitor side to suport that end of the board.
Also, are these boards available with the regulartor boards on this post?
REGULATOR PSU protel layout share
Thanks Troy
Old 29th July 2004, 04:57 PM   #9
Digi01,
We can't get away from some complications when they should be dealt with. The bypass capacitor on the mute pin should be there. Find a way to lay a track on the side, need not be wide, and bypass it to a ground, any ground.
Recently I read on this forum that N/C pins are really so: they are not connected.
If that is so then you can put a pad, solder the N/C pin to it and still put a track or fill over that same area. When I designed my pcb I simply snipped the N/C pins away and used their area for more copper surface.
The -V and +V tracks should definitely be wider, and it shouldn't be hard to do it. I did a single sided pcb for all this, with no wire bypasses, and everything went fine.
Carlos
Old 30th July 2004, 01:11 AM   #10
digi01's Avatar
Hi Troy,I will start another thread for group buy soon.Now, just share with you my DIY precious..hehe...
the regulated psu lay out projects is sitll in progress.the board cooperates with my 3886IGC.
Carlos,it is really?Soooooo pretty tidings I will test it.
3886IGC protel layout share digi01 Chip Amps 16 7th June 2004 02:27 AM
Page generated in 0.11361 seconds (78.00% PHP - 22.00% MySQL) with 11 queries
