Old 22nd July 2004, 11:24 PM   #1
Send a message via MSN to porfi4ever
Default Finished GC : Sweet & sour experience!!!
Hi everybody, I just finished my GC base on Brian's Boards and Peter's chassis, but like the subject says it was a sweet and sour experience. Sweet, because the layout boards are wonderfull and the chassis is superb!!(this 2 guys are great) and sour because when I connect the amp to power, loud sound was coming from it. I took a reading of a dc offset and it was 34 dcv same reading after rectifier. I have a doubt and it is in my rca wiring with the grayhill switch, If I mess there could it be the cause of my problem. Please help me, I'm just a newbie.
Old 23rd July 2004, 08:18 AM   #2
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
Check all your solder joints very carefully.
Make sure that you have the capacitors in the right way round.
It looks as though one of the voltage rails is broken somewhere between the output of the PSU section and the input pin of the chip.
Do not connect a speaker until the DC offset is under 100mV.
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 23rd July 2004, 07:10 PM   #3
Thanks Nuuk for your response, think I found the problem, pin #3 is the one that goes connected to binding post +? if this is correct Ihave the FNB connected to pin #4. Am I correct? please
Old 23rd July 2004, 07:17 PM   #4
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
pin3 is the output (connects to + on binding posts), pin4 is V- (negative rail) , pin 1 is V+
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 23rd July 2004, 07:21 PM   #5
Thanks Peter, I was a stupid. I connected to pin #4.
Old 23rd July 2004, 07:34 PM   #6
I thought you were using Brian's board and not p2p circuit
www.audiosector.com
Old 23rd July 2004, 11:34 PM   #7
Yes, I'm using Brian's boards but got confused,then I connected the resistor to wrong pin but solved that problem, now I'm getting 48.6 mv for right channel and 52.2 mv for left ch. Are these readings fine?
Old 24th July 2004, 12:00 AM   #8
Those are fine.
www.audiosector.com
Old 27th July 2004, 02:06 AM   #9
But after fixing a problem with a channel I'm getting 13.5 and 10 mv , are they ok? Amp is playing wonderfully!! It is dead quiet. No pic right now, having problem with browser.
Old 27th July 2004, 08:08 AM   #10
Nuuk's Avatar
Yes, absolutely fine. All's well that ends well. Happy listening!
I need help on a sweet project mryoumans Everything Else 3 16th April 2008 12:33 PM
Sweet tweeter Guss Multi-Way 12 6th July 2003 01:28 PM
Sweet! (Bag End InfraSub) BAM Subwoofers 5 13th January 2002 04:13 AM
Page generated in 0.13236 seconds (69.45% PHP - 30.55% MySQL) with 10 queries
