| Chip Amps Amplifiers based on integrated circuits |
#11 | |
Thanks Nuuk |
#12 |
Dumb Question: between what points do you measure DC offset from?
#15 |
My GC continuous playing wonderful music, this is an amazing amp!!I would liked to know guys if I can connect my GC to a pre-amp.
#16 | |
The truth need not be veiled, for it veils itself from the eyes of the ignorant. |
#17 | |
Thanks Nuuk for your response, but let me tell you my GC has volume pot, it does not matter? How I"m going to control the amp : with pre-amp volume or amp volume. I hope this set-up does not explote my GC. Thanks again Nuuk. |
#18 | |
If you find that the preamp works better with your GC that just an amp volume, you might permanently disconnect the pot in the amp, making it the power amp only (and not integrated). You might also experiment which pot works better: when you have the volume set at max position, the effect of the pot is reduced. Try to use only preamp volume first and then try the amps volume only. Compare which sounds better.
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#19 | |
Thanks Peter, I'm going to do that. The GC by itself works fantantic I just want to use my pre to benefit from my subwofer, |
#20 |
Before you remove the pot from your GC, can you let us see your circuit? You may need to add a resistor from input to ground in place of the pot.
| I need help on a sweet project | mryoumans | Everything Else | 3 | 16th April 2008 12:33 PM |
| Sweet tweeter | Guss | Multi-Way | 12 | 6th July 2003 01:28 PM |
| Sweet! (Bag End InfraSub) | BAM | Subwoofers | 5 | 13th January 2002 04:13 AM |
| Page generated in 0.44943 seconds (100.00% PHP - 0% MySQL) with 9 queries |
