Old 22nd July 2004, 08:49 AM   #1
MWP is offline MWP  Australia
Default DAC + bridged gainclone idea...
Hello all,
Is there anything conceptually wrong this idea?
The DAC will be a BB item like the PCM1730, PCM1794, PCM1798, etc.
I realise there is no volume control, but that isnt a problem.
Thanks!
Old 22nd July 2004, 08:56 AM   #2
Originally posted by UrSv
Could it be that the DAC plays at a fixed level meaning that you will play at maximum all the time without possibility of adjusting the volume?
Yup.... but thats why i said to forget about the fact it has no volume control
Ill add a simple course resistive relay switched vol control between the I/V opamps and the LM3886, then use digital volume control before the DAC for the rest.
But that would have overcomplicated the schematic, so ive left it out for the moment.
I havnt built this yet... i would just like confirmation from some of the other brains here before i spend the time making the PCBs, building it, etc.
Old 22nd July 2004, 09:12 AM   #3
borges is offline borges  Norway
I like your idea. Actually, I've been thinking about the same kind of thing, only with a digital crossover filter. But before I get there I have to get my design to work properly as a DAC.
I have my own oversampler up and running in a Xilinx FPGA, and modifying the filter coefficients for xover use shouldn't be that hard. If you trust the oversampler of the PCM1794, it should be possible to receive a digital 16bit/44.1 mono signal, filter it and present a "stereo" 16bit/44.1 signal to the DAC with one channel for each speaker element. Personally, I oversample on my own, so I'll need one converter for each element (no-df mode or whatever they call it.)
But you will still need some kind of volume control. I haven't yet started looking at digital potentiometers and programmable-gain amplifiers yet. But tell me if you find some promising ones!
Greetings,
Børge
Old 22nd July 2004, 10:10 AM   #4
Well this will actaully be used with digital xovers.
But from a PC (Linux + BruteFIR).
So, ill be making 3 of these PCBs (stereo out each) for Sub, Tweeter L&R, Low L&R.
Ive now decided ill be using PCM1798's in mono mode for the outputs.
The I/V opamps will be OPA627/637s (eek, ill need 12 of them!).
Old 22nd July 2004, 11:11 AM   #5
banana is offline banana  Hong Kong
TI suggest similar config with their new TPA6120 headphone amp IC. If it works on headphone amp, I don't see why it doesn't work on speakeramp.
TPA6120 datasheet
Even wilder idea in my brain. I was wondering using chip amp as the I/V directly!
Old 22nd July 2004, 11:36 AM   #6
Yeh, i thought about this too, but it would mean the LM3886 would need to have quite high gain and very limited low-pass filtering.
[edit]
BTW, thanks for the link to the datasheet...
Old 22nd July 2004, 01:16 PM   #7
i'm thinking about the same thing and the design is almost done.
the implementation is like what Banana have mentioned.
Old 22nd July 2004, 01:19 PM   #8
Care to put a schematic up?
Old 22nd July 2004, 03:32 PM   #9
Oh.
One thing ive just thought of is that there is a Vcc/2 (2.5V) offset on the DACs current ouput pins.
With other DACs there is a VCOM or similar that is used to cancel this at the IV converter opamps.
With the PCM1798 there isnt such an output pin... they assume that the -Ve and +Ve offsets will be canceled at the ouput opamp.
To you guys have any ideas of how i could cancel this out without using series caps?
Old 23rd July 2004, 03:32 AM   #10
Hi MWP,
Check out page 13 on AD1955 datasheet.
AD1955 datasheet
The concept is to inject DC nulling current into I/V's virtual ground summing node. Either current sourse or pull up resistor works. Or maybe servo works too, I suppose.
I've used the pull up resistor method in my AD1853, works great.
(NOISE) Gainclone with bridged LM4780 nickthevoice Chip Amps 13 26th November 2007 03:21 PM
Power supply for bridged Gainclone Mrpong Chip Amps 1 1st July 2006 04:28 AM
It works (DAC + Bridged Gainclone)! MWP Chip Amps 5 9th September 2004 09:37 AM
Bridged Gainclone? 2Bak Chip Amps 4 22nd February 2003 06:36 AM
Page generated in 0.10516 seconds (78.48% PHP - 21.52% MySQL) with 10 queries
