| Chip Amps Amplifiers based on integrated circuits |
Hi...
I really wanna get this built, but as its my 1st amp project and I'm laying out and makin my own pcb I gotta make sure the fikker will work... Here's the latest schem (for 1 chan) based on the datasheet circuit and info given for the 'DESIGN A 40W/4X AUDIO AMPLIFIER' bit... Are the values of components ok? Is where I've put either S or P gnd ok? I'll be using a stepped att instead of a pot... Thanks > again. |
#2 |
Why are you using an INA134 balanced chip? Are you going to feed a balanced signal?
If not you should do better with an OPA627 or similar, used as a buffer or line amp. The main purpose and design of a differential chip is to keep CMMR high, so other specs are not as good as non-differential chips. Then you can put your pot, stepped or not, before that chip. Putting a pot before a differential chip may invalidate its advantages. Putting it after that stage would be foolish. So, again, why do you need a differential stage? Carlos |
#3 |
because Im feedin a balanced input
#4 |
You must get to + input resistor to the ground ( 100 kOhm ) and AC separed pot by cap 1 micro. If you don't do it, pot will be rattle and output offset will be slide depend on turning of pot.
#5 |
Well, got one of these GC's built then
![]() I ended up using this the pcb from this site: http://www.dpaton.net/audio/3886amp/3886.shtml with a few alterations. The rest (balanced rcv/psu) was done with stripboard and p2p - this was my 1st amp afterall so I thought I may as well bodge it... The housing I used is from a old 40s radio I found under the stairs - a sand n varnish and came out quite nice. the vol att is 22k 12Pos... Sounds fantastic I gotta say. |
#6 |
It looks good in any case, I like these wooden cases. Unfortunately I'm not that good in woodwork.
The attenuator switches incl. mod look quite familiar Looking at the photo it seems you use the same switches as I do, but you seem to have found switches with more than 2 decks if I see right?regards, Maarten |
| Help to understand this schem please! | apr | Instruments and Amps | 11 | 1st January 2009 08:06 PM |
| schem for LM1875 PCB | missieek | Chip Amps | 1 | 29th October 2008 09:31 PM |
| LM3886 schem, feedback cap. | Ivarsson | Chip Amps | 6 | 23rd July 2008 12:59 PM |
| Tip33.....anyone got a schem. | diesel_tech | Solid State | 9 | 23rd March 2007 11:55 PM |
| help, schem for sherwood | psychosteve | Solid State | 0 | 10th November 2004 05:35 PM |
| Page generated in 0.09117 seconds (67.74% PHP - 32.26% MySQL) with 10 queries |
