I got 8 pcs. of trafo rated 12-0-12 3amp each. I wonder if i can use this trafo in regulated PS. My plan is to leave the center terminal unconnected and used 1 trafo for positive regulator and 1 trafo for negative regulator. Is this possible??
and since LM338 got 32v(V-inMax) can i used 24v secondary?
