Old 20th July 2004, 12:22 AM   #1
xplod1236's Avatar
Send a message via AIM to xplod1236
Angry LM3886 overvoltage
What will happen if I apply too much voltage to the LM3886?
The max voltage for the chip is +/- 42, so what will happen if I feed it 45v?
Old 20th July 2004, 01:06 AM   #2
mrrao is offline mrrao  China
not guaranteed Outgoing Quality Level .
propositional supply voltage under +/-42V
Old 20th July 2004, 02:29 AM   #3
Jay is offline Jay  Indonesia
Although there is a bit inconsistency in the pdf, it is
shown in the summary page that LM3886 features a wide
operating voltage up to 94V, which is +/-47V with split
power supply. Although there is no condition specified
I think good manufacturers should employ a safety factor
in the specs.
I'm not anywhere near afraid to feed mine with 45V, and
I don't think it will be blown up. The conditions are:
1) I employ a good practice in sinking the chip to the
heatsink. If the heatsink is hot, then make it biger.
2) My speakers are 2-way and cannot withstand too much
power anyway (about 50W average). Never measured the
speaker but I guess it won't go below 3 Ohm.
About heatsinking, it is very crucial. A trapped air due
to uneven surface may lead to the chip withstanding heat
it doesn't supposed to. IMHO, the chip failure must be
started with (slow) overheating, except when oscillate.
Old 20th July 2004, 03:08 AM   #4
xplod1236's Avatar
So if I keep the chips cool, it will be good?
I once ran the chip on +/- 50v rails, and it worked. Then, for some reason I don't remember, I disconnected the signal while the amp was on. When I went to connect the signal again, I don't remember exacly, but I got a spark from the signal plug to the jack. That went to the chip and fried it.
G2 overvoltage ?? puginfo Tubes / Valves 3 30th July 2009 03:18 AM
Cap overvoltage risk? Khron Power Supplies 14 29th June 2008 04:05 AM
BD139/140 Overvoltage B.I.G Solid State 17 22nd July 2005 09:12 AM
Overvoltage to LM4780 Mr Teal Chip Amps 18 20th February 2005 04:11 AM
overvoltage in my DC-DC theChris Parts 7 13th November 2002 02:37 AM
Page generated in 0.07745 seconds (73.96% PHP - 26.04% MySQL) with 10 queries
