| Chip Amps Amplifiers based on integrated circuits |
well i needed somthing to do so i tryed making another one with a
33 volt transformer and some caps on the power supply. wow this amp is loud but no heat . no caboom yet 33v + 33v 2.8amp transformer kinda overkill lol and the meters are working
#2 |
later
#3 |
looks good no problems. and i dont get the dredid hum when there no input. dead silent
i made a few changes to the original smatic. i will post it when i take it apart. this sucker has power and a lot of base. and verry little heat
#4 | |
No wonder they use them in all the boom-boxes! -Matt |
#5 |
That must be a very good sounding transformer you have there ;D
That is the smallest heatsink I guess. No heat? You must use it to feed Sony bookshelf speaker ![]() The green caps, are they supply pins bypass? What brand? The bigger ones, they look like 1000uF/50V Black Gate. I always try to use the cap as close as possible to the pin (no long cable). OK, you have those green caps Sound silly, but the 1000/50seems to not like working with other caps. In my preamp, adding another 1000/25 Pureism led to horrible sound. Even the 47uF Black Gate N must leave the PCB and replaced with 5nF SilMic,another silly judgement. Blame my ears. |
#6 |
beautiful
I have seen some white block things,is it film caps?what about the amp sound? congratulations |
#7 |
what are you using for meters? and what do they measure.
#8 | |
but i may go with white led's the light's make a lot of heat the sound is great punchy at high volumes. i made changes but there out of view under the boards i need to right down everything i did so i can make more
#9 | |
i made up a little board i found here. thay dont jump around like the cheap ones. thay hover at the right voltage from the amp i set it up with a voltage meter and a resister. its allmost right maybe off by a volt http://sound.westhost.com/project55.htm |
#10 |
heres how it is set up. kinda sad looking
i was just playing around with a chip and ran into it. feel free to pic it apart.what works for me may not work for you hay but it works so im not touching it ![]() after the transformer and rectitier and the 2 power caps the amp is runing on 41v ![]() the cap on the output turn it around its backwards |
| Freebird + Gainclone = "integrated" gainclone? | bikehorn | Chip Amps | 9 | 5th January 2006 03:07 PM |
| JLH v Gainclone? | Jezz-the-Fezz | Solid State | 5 | 12th December 2005 12:08 PM |
| Big gainclone | steven344 | Chip Amps | 10 | 23rd November 2005 07:58 PM |
| Page generated in 0.10595 seconds (87.69% PHP - 12.31% MySQL) with 11 queries |
