| Chip Amps Amplifiers based on integrated circuits |
I have a toroidal TF with a single primary, and dual 44V secondaries. I'm not sure about its VA rating but the thing is big (6x6x3, 18cable). I was thinking about using it with Brian's boards. Any suggestions as to the best way?
One way might be to use 2 of the power boards in series per secondary. That would give me 22V. Another would be to bleed some of the current to ground via a resistor, but I'd be worried about picking humm. |
#2 |
That's way to high for a GC, sorry.
Can you unwind some turns of the secondaries?
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#3 |
Yes, that is a possibility, but I wanted to know if anyone has tried the other solutions.
#4 |
Dropping current would be very wasteful, and need huge power resistors, as well as not providing very good regulation. Connecting in series would also not work, as it would be difficult to provide a reference earth, and resulting DC caps needed on the output. You would be better using the single supply schema in the datasheet if you wanted to use the traffo you have.
#5 |
A little guess may say that your tranny is about 500-800VA.
44V secondaries could give you +/-62V rails. you could use rod's P101 or P68 for that. it is way too high for an LM3876. |
#6 |
I'll take a look at the datasheet again. Thanks.
#7 |
you could also build a regulator circuit...MAJOR heat dissipation via some transisitor though...
Doovieman |
| newbie with input tran. question and wiring question | imo | Solid State | 0 | 18th January 2006 10:10 PM |
| Capacitor Question /question on cap | TunaFish | Tubes / Valves | 14 | 12th January 2004 02:23 AM |
| PS question - tformer question actually | breguetphile | Chip Amps | 2 | 30th May 2003 01:29 PM |
| old speaker question, bullet midrange question & link to speaker project | wallijonn | Multi-Way | 10 | 5th November 2002 06:03 AM |
| Page generated in 0.07664 seconds (72.96% PHP - 27.04% MySQL) with 10 queries |
