| Chip Amps Amplifiers based on integrated circuits |
Roughly how much current does one channel of gainclone draw using LM3875?
Has any one tried using choke in the power supply current? Would I need to put the choke on both +ev and –eg rail or just positive will do? |
#2 |
Is it anywhere in the spec sheet? Im guessing it draws 1 or 2 amps because people recommend about 80VA per channel.
I would like to know about the choke as well, havent seen anyone use them yet. Maybe because the cost and size needed to safely handle these amps? thx |
#3 |
That explains why people are not doing it, the choke with with few henrys for such current would be large and expensive.
#4 | |
The current will depend on the amount of power you want to put into the speekers and their impedance too. |
#5 | |
All will be revealed on the National Semiconductor website -- they have a Microsoft Excel spreadsheet program which gives y ou the peak current values in single, bridged and parallel mode: http://www.national.com/appinfo/audi...gn_Guide14.xls it seems as if i have to answer this question once a week. moderator, perhaps we need an FAQ |
| Gainclone with current-dumping afterburner!! | Circlotron | Chip Amps | 55 | 7th December 2004 08:25 AM |
| Gainclone sucking back Current | rayban68 | Chip Amps | 14 | 12th May 2004 03:58 PM |
| Gainclone Current | Matttcattt | Chip Amps | 24 | 9th January 2004 04:17 PM |
| current draw on a gainclone? | cowanrg | Chip Amps | 9 | 9th August 2003 06:58 AM |
| Page generated in 0.11122 seconds (64.74% PHP - 35.26% MySQL) with 10 queries |
