Old 16th July 2004, 08:39 AM   #1
Default Different GC
I did some design of GC from my idea and simulate it by Spice. I got good result from the simulation. But some mistake maybe occured that I don't know . Please help me to consider and comment this circuit.
Old 16th July 2004, 09:12 AM   #2
getafix is offline getafix  Philippines
getafix's Avatar
I think you meant to attach the schematic diagram
forever dreaming of a better set-up...
Old 17th July 2004, 03:42 AM   #3
Yes, I meant the schematic. I think that it's missing. I would attach it again.
Old 17th July 2004, 01:23 PM   #4
This does not work. Since you are feeding the input signal to the inverted inputs of each amp the signal between the output pins will be zero (however, there will be a signal between each output pin and ground).
Old 17th July 2004, 03:20 PM   #5
Thank you for the comment. From simulation result, output signal is not zero but it's amplified sine signal.
Old 17th July 2004, 03:44 PM   #6
Ignore my previous post. That was a brainfart. I was thinking about something completely different.
What is your specific problem with this circuit?
Old 17th July 2004, 05:12 PM   #7
analog_sa's Avatar
I don't see anything strange or unusual other than the very low input impedance. Just a balanced GC - pretty much the same as a bridged GC only lacking the inversion stage.
Old 18th July 2004, 04:09 AM   #8
Yes, it's a kind of balanced GC but different a little bit. From your comment, how much should input impedance be?
Old 18th July 2004, 03:50 PM   #9
djk is offline djk
djk's Avatar
Your input impedance is 1K in parallel with 47K, or 979 ohms.
Old 20th July 2004, 02:38 AM   #10
Yes, I thought it's too low input impedance. I think I will change all R 1k to be 40k and feedback resistance will be change to be 800k or 1M. I think it'll be better.
Page generated in 0.08204 seconds (76.55% PHP - 23.45% MySQL) with 10 queries
