Old 20th July 2004, 02:23 PM   #11
GregGC is offline GregGC  Canada
To get a better DC output offset you need to have R19=R4||(R10+R7) and R20=R5||(R11+R8).
Why didn't you use Non iverting topologie? It'll solve the low impedance voltage much easier.
/Greg
Old 22nd July 2004, 02:56 AM   #12
Thanks for the suggestion. I think that inverting type challenge me to design balanced GC more than non inverting type. But I think that my new design might be better. neither non inverting and inverting type.
Old 22nd July 2004, 06:00 AM   #13
djk is offline djk
djk's Avatar
It helps to have input bias.
If using an FET opamp like an OPA604 use 470K from pin 3 to ground on both U2 and U3.
Old 22nd July 2004, 07:55 AM   #14
Is it not too high input impedance? What's your idea if R100k is connected pin 3?
Old 22nd July 2004, 08:07 AM   #15
djk is offline djk
djk's Avatar
Do you know how to read a spec sheet?
The input impedance of an OPA604 is 10^12 ohms
(1,000,000,000,000)
Virtually anything will work, your design had nothing.
Nothing doesn't work.
Old 23rd July 2004, 03:03 AM   #16
Yes, I know how to read spec. sheet but at that time I had no spec sheet on my hand, I just downloaded it to read the spec. Anyway, I have simulated with both input impedance 470k and 47k by PSpice. The output waveform results indicated me that 47k better than 470k. Eventhough the simulation results indicated 47k better but I will try the both because in actually maybe R470k will be better. By another thing, R470k is matched with C 0.1uF that is cheaper than C 1uF.
Page generated in 0.07447 seconds (70.09% PHP - 29.91% MySQL) with 10 queries
