Old 16th July 2004, 06:21 AM   #1
jtfoo is offline jtfoo  Singapore
Default Question on gain setting when bridged
I'd liked to build a multichannel amp(using LM4780) for home theatre (HT). I intend to parallel/bridged the front left/right and centre channels. While the surrounds channel will be single ended chip. Since it going to be for HT purposes, I'd want all channel to have the same gain.
Say, I configured the gain of the surround channels to 20. What will be the gain to be configured for each chip amp that are to be used in the bridge/parallel configuration so that the final gain from them will also be 20? I'm thinking since they are bridged, I should configure the gain to be 10 for each chip amp, since voltage swing will be doubled. Not too sure though.
Old 16th July 2004, 11:06 AM   #2
squadra is offline squadra  Netherlands
squadra's Avatar
Yes, the gain is doubled in bridged mode.
According to the application information gain should be between 10 and 50 (see page 17 of this doc .)
Maybe a gain of 10 is too close to the limit, I think you would be better of choosing 30 as gain for the singular devices and 15 for the bridged versions.
Old 16th July 2004, 02:21 PM   #3
Thanks Squadra.. Just the info I needed to get started.
Help with GainClone gain setting johan851 Chip Amps 35 15th February 2008 05:33 PM
Setting GAIN on GAINclones Lucas_G Chip Amps 11 20th December 2006 07:33 PM
Gain Setting HU/Amp vadi Car Audio 2 19th July 2006 11:57 AM
Opamp gain setting resistors values deduikertjes Solid State 7 20th June 2006 06:59 AM
Gain of Bridged-Paralleled Gainclone Vs. Regular NI GC PHilgeman Chip Amps 0 2nd July 2004 02:48 PM
Page generated in 0.09303 seconds (62.49% PHP - 37.51% MySQL) with 10 queries
