| Chip Amps Amplifiers based on integrated circuits |
Is a GC amp able to power a sub?
What kind of power can be expected from one of these? Ive never tried building one before but I really wnat to have a go. Are the able to drive a 4ohm load? Or are they more for really sensitive easy to move speakers? |
#2 |
Depends on what type of sub?
The 3886 chips will drive 4 ohms and you can use more than one amp to increase the power output. If you have never built a GC before, build a basic one and try it with your main speakers. That should give you the experience and knowledge to build something to drive that sub.
The truth need not be veiled, for it veils itself from the eyes of the ignorant. |
#3 |
Ok then.
Thanks a lot for your help. Think ill get ordering the components this weekend
| 40A 250V Schottky Power Diodes- Has anyone use in Power Amp to replace Diode Bridge? | dtm1962 | Solid State | 10 | 15th September 2011 07:38 PM |
| LTspice tool for power amp power supply component evaluation | andy_c | Software Tools | 2 | 23rd August 2009 05:10 PM |
| Power transformers versus amplifier output power..what is your option? | destroyer X | Solid State | 38 | 9th May 2009 05:23 PM |
| Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality | MARAVILLASAUDIO | Class D | 1 | 5th November 2004 04:06 PM |
| power output calculations, rated power and required power output | metebalci | Tubes / Valves | 7 | 22nd February 2004 05:49 PM |
| Page generated in 0.06411 seconds (71.49% PHP - 28.51% MySQL) with 10 queries |
