| Chip Amps Amplifiers based on integrated circuits |
Hi
I started looking at amplifier chips a few days ago, and found this site. It has been a great source of help, just reading it. Now to my question. It seems to me that most people use four diodes for rectification (is that a word in english?). Is there a reason to not use a integrated rectifier bridge (if that's what it's called in english, what I mean is a chip with four diodes connected as a rectifier bridge)? Erik |
#2 |
You can see the bridge here. There has been a lot of discussion on the use of normal rectifier diodes vs Shottky rectifiers, or high speed diodes. But personally I like the bridge, basically anything thats nicely packaged and closely thermally coupled will have an edge over discretes is my belief. So...
What is not shown in the PCB is provision for some snubbers.. I plan to put them directly on the pins, on the solder side. ajju |
#3 |
Use the integrated bridge rectifiers. Less work, usually higher current rating, cheaper, easier to replace, etc.
There's really no reason to use seperate diodes. Some people claim that faster diodes work better, but this is 60Hz - it doesn't matter since even the slowest diode in the world will be many times faster than this. Snubbing caps across the pins is a good noise prevention measure if you feel like it, usually not required but cheap so why not. Some also claim that it makes a "sonic" difference if you get the individual diodes. These are usually the same people that claim that a $500 oxygen-free copper "super duper" mains power cord to feed your equipment will improve the sound of your amp. ![]() But they are right to some degree -> it does make a sonic difference. No sound will be coming out of your speakers when you can't afford to pay the electric bill becuase you spent your money on expensive high speed diodes
#4 |
Just use a bridge. I'm sure that some people claim that their "fast action" diodes make a sonic difference, but a bridge works just fine...you can also get a "fast action" bridge if you so choose.
#5 |
What about paralell connection of two bridges? Any problems there?
Erik |
#6 |
No problem at all.
#7 | |
diyAudio Senior Member
Frank |
#8 | |
And why with the cheap snubber caps? Some people don't rely on numbers. I have been happy using MUR120/140/160/480/860 etc. May be it is not because the 50ns, may be it is just because Motorolla has great machines. But who cares with the machines?Some says price doesn't lie. Well, may be not true but motorolla diodes are not expensive when we talk about high end systems. If I cannot hear the difference in the separate diodes, I will still have no reason to not use it, except the relative difficulty in assembling. As with snubber caps, I cannot hear the difference, but I have a reason to not use it. Because you should not add anything to the system unless you know what it can deliver. |
#9 | |
One of sufficient capacity will work fine. Cheers, John |
#10 | |
| Bridge rectifier vs Full wave rectifier | hilbert_mostert | Tubes / Valves | 4 | 28th April 2009 08:26 PM |
| FS: Lot of IR rectifier diodes | luvdunhill | Swap Meet | 1 | 4th February 2009 02:19 PM |
| Rectifier diodes for UcD 400 | m.parigi | Class D | 6 | 14th March 2005 09:42 AM |
| Rectifier Diodes | richie00boy | Parts | 6 | 19th April 2004 01:41 PM |
| GaAs rectifier diodes | ergo | Parts | 1 | 13th August 2003 04:45 AM |
| Page generated in 0.14030 seconds (68.74% PHP - 31.26% MySQL) with 10 queries |
