Old 13th July 2004, 01:31 AM   #1
Send a message via AIM to Chris8sirhC
Default gainclone shielding
How much shielding do you need to incorporate into your gainclone. Will copper mesh be enough? I have heard that the gainclone (brian gt) is more open to distortion from its surroundings.
Old 13th July 2004, 07:22 AM   #2
analog_sa's Avatar
None whatsoever works fine in most cases.
Old 13th July 2004, 08:36 AM   #3
Ropie is offline Ropie  United Kingdom
Ropie's Avatar
Well, it depends what your case is made of. A metal case will do the job of shielding quite well A wooden or plastic case will probably need some kind of shielding - I have my wooden case lined with aluminium foil but can still ocassionally pick up the taxi radio if one drives past.
The important thing is to earth the shielding (or metal case) via a cap and resistor (in parallel).
Shielding ..... sakis Solid State 9 20th July 2009 07:34 AM
Shielding? ROBSCIX Analog Line Level 7 27th October 2006 05:28 PM
Shielding Lostcause Everything Else 12 8th November 2005 02:30 PM
Shielding KornChild5 Everything Else 0 3rd May 2005 06:37 AM
RFI/EMI Shielding, is it necessary? mkruger Parts 1 22nd April 2004 05:54 AM
Page generated in 0.07257 seconds (62.71% PHP - 37.29% MySQL) with 10 queries
