| Chip Amps Amplifiers based on integrated circuits |
This is the pcb I have designed for the LM3886T device.
Before I have the pcb's done it would be nice if people that know a thing or two about pcb design could make some comments about this design. Remarks: - SMD1 & SMD2 are 100 nF caps, soldered to the bottom of the pcb. - The hole for pin 3 of the LM is placed a little forward to make some room for the trace from Pin 1 to 5 to be wider. - Rectifier & buffering is on a separate pcb. Better not use an exact copy of pcb, the dimensions of the LM are wrong, as Layo doesn't have the multi-watt package. (or maybe I just couldn't find it, after all it's my first try. That might also explain why it took > 6 hours And for some reason if I scaled the file to something smaller than the original size the file's size got bigger. Therefore I attached the bigger but smaller file
#2 |
A few small changes:
- Found out how to create my own library elements, the lm3886 now has the correct pin layout & spacing. - Moved GND pin to the middle, looks more like a star now. - Moved mute resistor so it is completely below the LM avoiding shortcircuit with the heatsink. - Added parts for Zobel network. - Boardsize is 5 * 4 cm, 1 euro card can accomodate 8 of these pcbs. Image now is smaller too, just 25k
#3 |
i think you better put also the holes not in use for the PCB in the LM3886 legs,
like every IC design, you put the full package detail...because if u dont drill that you just need to cut legs... ![]() 11 holes i assume? if u have the schematic i am looking for a good & max.usage of this chip for max. power ![]() thanks |
#4 | |
I am going to cut pins 2, 6 & 11, mainly because I need the extra space for wider traces. I'm basically using the schema as in the datasheet. Some parts values have changed, and since I don't like elco's in the signal path I have moved the DC blocking cap to the input. Partlist for this pcb: Rin: 47k Rb: 1k Ri: 1k2 Rf1: 18k Rm: 22k unnamed 1E for zobel network Cs(2x): 220uF elco + 100nF SMD unnamed 3u3 cap @ input unnamed 100nF for zobel network |
#5 |
ok, well still i dont recommand cutting legs....
even if they are NC in the inside schematic there can be errors. like if someone takes this PCB layout and cut the wrong leg or the chip itself can be less stable (phisicaly).... u can still bridge legs 1 and 5 without hurting leg 3... b.t.w how u make the PCB after you draw it? |
#6 |
Squadra,
I agree with morbid, cutting of the pins is not a good idea. But if you want to do it, at least try to get the right pinnumbering on the chip, now it is quite confusing and you can bet somebody, sometime, maybe even you, will measure the wrong things or make a wiring mistake. Question: I assume that one of the holes in the star ground is for the speaker return? Do you have a ps with a center tap? If you have two separate supplies, it would be good to run the returns of both to the star ground, then you need one more hole. BTW Nice layout, looks pretty optimal to me. Jan Didden
/Another new issue: Linear Audio Volume 3! |
#7 | ||
If I don't cut pin 2 and leave 3 inline then the trace between pin 1 and 5 will be very small, too small for me. I have returned pin 11, there was no reason to cut that one. I will send the gerberfiles to a company that creates pcbs, I have no means of creating the pcbs myself. Quote:
Speaker return? ![]() I plan on using a PS with separate grounds for V+ & V-. Together with the speaker return I need 4 connections at the star ground. So, again a new version
#8 |
Lead not input ground throuth output ground, but beside by independent line to the middle of PS. Get input cap to the middle of PCB commonly with input groung. After that all will be OK
#9 | |
Your tips lead to the newest attachment ![]() Tnx, Pj |
#10 |
Getting better all the time. You may want to put the input gnd pad close to the input hot pad, makes it easier to solder the screened cable from the input. Run this pad with a short track to the start gnd.
The speaker output pad seems floating, or is there a jumper? Anyway, move the speaker pad to the right side of the electrolytic. Avoids speaker current under the cap. Also, move the V+ and V- pads closer to the chip, above the elcap, makes your pcb more compact and avoids unnessesary track length. Jan Didden
| lm3886 layout | jesserparker | Chip Amps | 1 | 16th January 2007 10:29 PM |
| Please check this LM3886 layout for me | CJ900RR | Chip Amps | 7 | 26th February 2006 08:35 PM |
| How about our project of LM3886 layout | AlivinCai | Chip Amps | 4 | 12th December 2003 11:31 AM |
| Page generated in 0.13558 seconds (74.39% PHP - 25.61% MySQL) with 11 queries |
