| Chip Amps Amplifiers based on integrated circuits |
How much power can I expect from a bridge/parallel LM3886 chip amp? The supplies would be +/- 35, and the load would be 1.35 ohms (4 x 5.4 ohm coils in parallel). I should get 64v across the load, so mathematically, the max power output comes out to 3,034 watts. Would I get 3 kw to the speakers plus heat, or will the power draw be 3 kw, and that will be split up for output/heat?
#2 |
Lets do some educated guessing. No signal, the LM takes, what, 50mA at 70V total, that's 3.5watts to begin with.
Now, suppose your average power output is 10 watts RMS (I'm being generous here) in 1.35 ohms, so I=sqr(10/1.35) which is about 2.7A RMS. Over the load you will find 2.7 * 1.35 = 3.6V RMS. The remainder (35V supply is about 25V rms for comparisons), over the chip's output transistors (thats where the heat will be) is about 21.5V rms. This will give a dissipation of P = 21.5 * 2.7 = 58 Watts, bringing the total just over 60 watts. Which is too much for continues 10W output. Did you spot the problem? Your supply voltage is way too high for a 1.35 ohms load. You will have the chip limiting in current and/or dissipation long before you reach the max supply. In fact, if you lower the supply to 20V or so you can get more power out of this chip, at least in 1.35 ohms. But still, 4 ohms would be much better as far as using the max chips capabilities is concerned. Jan Didden
/Another new issue: Linear Audio Volume 3! |
#3 | |
Edit: I will be paralleling at least 5 chips on each side of the bridge, so at least 10 chips for the whole amp. |
#4 |
janneman is right.
However I would like to look at it from two different angels: A. You have a load of 1.35 ohm for a bridge/parallel amplifier. This means that each "arm" sees a load of 0.675 ohm !!!. With 5 LM3886 in parallel in each arm they each see a load of 5 x 0.675 = 3.375 ohm !!!, Not imposible to drive for a LM3886, but with a supply of +/- 35 V it is very much on the limit. B. Let say for a moment that you have a "perfect" PSU and a "perfect" cooling of all your chips. How much power can you get in a 1.35 ohm load ??. A specific power level in a specific load requires a specific level of current and voltage. You CAN'T "supstitute" one for the other. For a 1.35 ohm load you need: A Vrms Vpp 3000W: 47.1 63.6 180.0 1000 W: 27.2 36.7 103,9 500W: 19.2 26.0 73.5 200W: 12.2 16.4 46.5 With +/-35 V, I don't think you will get much over 100 Vpp, so if everthing else is "perfect" you MIGHT get around 1000 W in your 1.35 ohm. 3000 W is simply not possible no matter how "perfect" your PSU and cooling is. Have fun Thomas |
#5 | ||||
#6 |
The tabel is
Power Current(A) Vrms Vpp So for 1000 W you ned 27.2 A 36.7 Vrms 103.9 Vpp Remember it is a bridge design. Regards Thoms
#7 | |
the best way IMO is using standard BPA200 application (four IC's for one amp) for each speaker. (why paralleling them?) You can get ca 250W from each amp, and overall ca 1kW. Paralleling amps technique isn't ideal, and allways you have small disballance what can be huge problem. Regards Milan |
#8 | |
Banned
#9 | |
#10 |
"4 x 5.4 ohm coils in parallel"
-5.4 ohm speakers? my guess is for 6-8ohm nominal impedance. that brings the load impedance up to 1.5 to 2, unless the woofers really are 5.4 ohm nominally. i'm not sure a 10 IC (minimum) GC would beat out a simple class B amp. i assume this is for a set of woofers? in anycase, i'd go with seperate channels with less paralleling if possible. this means running extra wire though. also if one chip dies, well, it won't be hard to fix -- the woofer that doesn't work... that's the channel to fix!
if only it could be used for good, not evil... |
| Heat sinks for power supply? | jasmail2376 | Power Supplies | 2 | 16th February 2007 07:43 PM |
| Chip Amps w Built In Heat Sinks | zenmasterbrian | Chip Amps | 86 | 24th September 2006 07:26 AM |
| power transformer heat | tenderland | Tubes / Valves | 6 | 26th May 2005 06:10 AM |
| Heat sinking power per frequency ??? | Jennice | Everything Else | 8 | 16th July 2004 10:58 AM |
| Page generated in 0.12140 seconds (82.98% PHP - 17.02% MySQL) with 10 queries |
