| Chip Amps Amplifiers based on integrated circuits |
I have always wanted to build a 5-channel surround amp. Now I think I'm ready to finally start. But, I need some reccomendations on what chip to use. I want close to 200W per channel so it has plenty of power to keep up with the explosions in movies. The front needs to be able to drive 2 ohm speakers and the center and rear are 8 ohm. I was originally thinking of using the bridged OPA549 PCB design I already have. But, to drive a 2 ohm it would need 3 of those bridged boards paralleled together. So 6 boards for the front and 3 for the rest. That's 12 chips in the front and 6 in the back or 18 chips total. I would like to use less than that if possible.
What chip is simple enough to use and to make the boards for them myself, yet also provides enough power and is able to drive demanding speakers? Should I just go with the opa549 and make that many boards? |
#2 |
IMHO, 2 ohm loads are a tall order.
If it were me, I would reconfiguring the front 2 speakers say for at least 4 ohms. This would save you a lot of chips and troubles. Honestly i've never made a chip amp (yet), but from what I have read here on the forums. A 2 ohm reactive load would possibly make the protection circuitry on the chips kick in once they got good and hot, as the load can go much lower than nominal. I am just getting into this again after 15 years so consider this a newbie opinion at best. Good luck to you. |
#3 |
is anybody here?
please recommend a good chipamp for this task. |
#4 |
use transistor .
#5 |
too complicated...
Well, actually, is it possible to use a single high power transistor? I have some On Semiconductor MJ15003 and MJ15004 High Power Transistors. How much power can I get using those? And, how would I use them? |
#6 |
yes very complicated.
because high voltage. abvert smoke out. |
#7 |
HIGH VOLTAGE ====> HIGH POWER
YOU can get about 150W/4ohm with one pair of mj15003/4
B.I.G |
#8 |
Really? I thought that was way outside SOA for a single pair.
#9 |
could that pair of those transistors drive 2ohm, even 1ohm?
Would somebody mind helping me build this by designing a schematic? |
#10 |
anybody??
| axial surround instead of radial surround | Calvin | Subwoofers | 22 | 13th July 2009 06:46 PM |
| surround amplifier | jalejos | Class D | 11 | 7th January 2009 04:36 PM |
| Surround Decoder - Subtract amplifier | mod_evil | Tubes / Valves | 24 | 8th July 2006 07:41 PM |
| Pioneer VSX - D710S-G Surround Amplifier 4 Sale | NicolasGaal | Swap Meet | 2 | 1st January 2004 06:40 AM |
| For those of us with $$$, DIY surround | Tieftoener | Digital Source | 0 | 20th November 2003 06:06 PM |
| Page generated in 0.12786 seconds (67.84% PHP - 32.16% MySQL) with 10 queries |
