| Chip Amps Amplifiers based on integrated circuits |
It is my believe that the same 2 amps do not always sound the same.
The gain, the component, the path/cabling, the matched impedance (input z to pre-amp, output z to speaker). Some believe the Gainclone is good, some don't. IMO it is not just about Gainclone or not Gainclone. It is hard to explain, for example, by formula how a 1000uF Black Gate sounds better (may be) than 10000uF in that "Gainclone". I have experienced for example how a cheap axial blue Nichicon give a wonderful sound to the system, compared to many exotic caps when used as bootstrap cap in certain setup. Now I'm building a certain "Gainclone" setup to achieve what I have ever liked better than my tube amps (sound like a tube but fast like SS). Here is my plan: 1) The speaker may be the most important contributor. With sensitive or fullrange speaker I guess it is easier to produce "tube-like" sound with SS. But I think I will tailor my 3rd order to sound like tube amp ( ), eg. sweet at vocal or mid to high.2) Bride Of Zen. Single supply 60V. IRF610 is the sweetest (cleanest), but IRL510 has wonderful lows when things are ok. Clean supply will be the biggest problem. 3) LM3875 or LM3886. Capacitor at output. Single supply (30V or 60V). The supply is chosen such that it will feed the BOZ and LM3875 working as a single integrated amp (I'm not sure if I would try to use 30V for the amp and 60V for the amp, that is using 2x30V secondaries) 4) Then I will play around with: a) Gain or feedback. The worse the oscillation problem, the better. b) 2 or 3 output capacitor setups (one with Black Gates std, one with big caps from UPS) c) Impedance "between" BOZ and LM3875. The resistor quality is not important, but there must be a magical value ![]() Whatever the result, I believe this setup will be a success. Especially if I could get away with the distortion from the BOZ.
#2 |
Banned
What do you mean with "tube-like"? How would you describe a "tube-like" sound? From what I read on your post it seams more practical to put a blanket on your speakers. ![]() Oh, BTW, a trafo with 2x30v secondaries? That voltage is too high for these chips. |
#3 | |
With 4 chips the DC droops to 41.X almost 42V which is indeed not very safe. I didn´t have the baXXs to test it on heavy duty so far. I recall having read cases here in the forums where it worked OK and where the chip died so you have to decide. National engineers also recommend +-35V max which might be a bit too conservative... What I personally was thinking about to do with my transformer was to regulate it down. If you have the transformer already you could consider that otherwise buy one with ~25AC secondaries max.(unless you wanna regulate anyway)
jens |
#4 |
The "tube-like" came from another thread in solid state forum. But honestly I didn't know if a blanket can do the job.Yes 60V seems too high for an IC but I had a quick glance on the pdf and I read 90 something as the max voltage. But if 60V is not possible then I will use the center tap to get a 30V. I have a lot of transformers about this value. Joensd, I think 42V is okay with good heatsinking. I always paid extra good attention on putting transistors on heatsinks. Besides, who's gonna rock the neighbours with too much power
#5 |
Use a tube amp, try a Decware Zen.
#6 |
what if i put a chipamp in a tube would that work
would it sound tube like
#7 |
The way I look at it, if you want butter-like, use butter. If you want tube-like, use tubes.
se |
#8 | |
You took the words right out of my mouth.
#9 | |
![]() se |
#10 |
diyAudio Moderator Emeritus
I'm looking for a cheap Ford that drives like a Porsche.
Any ideas
| "Yuanjing" Gainclone 3886 - eBay amazing value ? | gainphile | Chip Amps | 520 | 18th April 2012 12:07 PM |
| What makes an amplifier "bright", "warm", or "neutral"? | JohnS | Solid State | 51 | 13th December 2009 06:42 PM |
| Building a high quality gainclone toroid coupling transformer with "tubeness" winding | ionomolo | Chip Amps | 16 | 13th February 2008 01:20 PM |
| Freebird + Gainclone = "integrated" gainclone? | bikehorn | Chip Amps | 9 | 5th January 2006 03:07 PM |
| Newbie wants to build a "GainClone-Like" 5.1 Channel Battery Powered Amplifier | captain | Chip Amps | 7 | 15th October 2004 12:35 PM |
| Page generated in 0.11848 seconds (81.88% PHP - 18.12% MySQL) with 10 queries |
