| Chip Amps Amplifiers based on integrated circuits |
I just built my first gainclone. I powered it up and it was very cool and everything looked fine.
Then i put a 10ohm resistor (.5W) on the output and it burned. I thought it was only because the amp was putting out more than .5W . I attached a 40W speaker to the ouputs and turned it on and the speaker buzzed at about 60Hz. Connected my MP3 player as an audio source and still only humming, not even distorted music. The chip, the wires and the PS stayed cool the whole time. I used a resistor instead of pot, and I am sure this is wired correctly. Trafo is 24vct 240VA EI type, maybe this is to low? thank you for any help you can offer. |
#2 |
I searched many threads and found many buzzing gainclones, and tried many solutions. The buzzing remained! the chip is a LM3886TF and i changed the pin wiring to accomadate. It is wired P2P and everything is protected.
#3 |
Banned
Where did you get that schematic?
That thing doesn't work! What are you trying to do? Inverting? Non-inverting? |
#4 |
Seems like you swapped the + and - inputs. The feedback is positive. This "amp" will act like a schmitt-trigger, and the output will be either v+ or v- (which contains a 60 Hz component).
#5 |
I found this schematic off the diyaudio threads. I figured it was the simplest one, and hence the easiest.
Thank you for the replies, i will attempt to change the inputs and see if this solves my problem. But I think that they are correct for the other schematic which i have from decibel dungeon looks similar. I will attach it so you can see what i mean. |
#6 |
#7 | ||
1) There should be some resistance from the non-inverting input to ground. Something like 22K should do. Offset will be lower. 2) There should be a series resistance at the output, from 0.1 to 0.47, 5W type. 3) The speaker ground should be connected to the star ground, not between the caps. Quote:
Carlos |
#8 |
thanks for the reply carlmart
my chip is an lm3886, but i changed the pinout accordingly, i will try to implement your advice, and thank you for taking the time to help. i will try to post my results on sunday. |
#9 |
While the original schematic doesn't seem to be very well thought out (I could see it easily leading to improper grounding) it does seem to be correct, though it took me a couple looks till I realized it.
Do you have both V+ pins on the 3886 supplied? What value mute resistor are you using? That aside, look to your grounding scheme carefully. Power ground and signal ground should be separate (with the resistor across the input going to signal ground star) and then connect the two stars with a thin wire. Output ground should come from power ground, and the caps from V+ and V- to ground should also go to power ground. I think I have this right. It may be worth triple-checking your pins and making sure there are no shorts, solder bridges, etc. C |
| Buzzing Pre-amp | stevebell | Solid State | 10 | 12th June 2008 03:26 PM |
| LM3886 Buzzing | Bengali | Chip Amps | 19 | 15th January 2007 07:29 AM |
| another buzzing 3875 GC... | cameo | Chip Amps | 10 | 30th August 2005 10:34 PM |
| Buzzing sound | Måsen | Digital Source | 0 | 13th March 2005 08:39 AM |
| Buzzing in A40 | NickC | Pass Labs | 9 | 25th August 2003 11:42 AM |
| Page generated in 0.12316 seconds (73.56% PHP - 26.44% MySQL) with 11 queries |
