Old 5th July 2004, 06:38 PM   #1
xplod1236's Avatar
Send a message via AIM to xplod1236
Angry Transformer rating
I'm planning to build a high-power amp using LM3886s in a bridged/paralleled configuration. What voltage secondaries should I use to get +/- 40v rails? Is 28v ac enough or do I have to go higher to compensate for diode voltage drop?
Let's say that I have a 1000 VA transformer. Is that good for a 1000 w rms amp or a 1000w peak amp?
Old 6th July 2004, 07:32 PM   #2
xplod1236's Avatar
anyone?
Old 6th July 2004, 09:39 PM   #3
ble0t is offline ble0t  United States
ble0t's Avatar
Well, the rectified output is approx 1.4 times the input of the secondaries. The diode losses shouldn't be too large a factor...
As for having +/- 40V per rail...that is probably too high. The maximum voltage input of the LM3886 is 84V. Allowing for voltage swing within your mains (conservatively +/- 5%) if you are not using a regulated supply, you could easily exceed that. Typically, for the LM3875 and LM3886, from what I have seen, 25V secondaries is the maximum you really want to use.
As for the power of the trans, to get continuous 1000W, you'd need to run quite a few of these suckers in a P/B config, so I guess you would need quite a bit of power...I'd refer to the datasheet for more info.
Hope that helps
gravity always wins
Old 7th July 2004, 12:58 AM   #4
xplod1236's Avatar
Default Re: Transformer rating
That was a separate question (just an example). I know that I will need to run them in P/B, and I know how to figure out how many I need.
The quesion was if a transformer is rated at 1000 VA is that continuous or peak?
Transformer rating ? woody Parts 0 31st July 2008 05:44 PM
Zen transformer rating!! sandstorm33 Pass Labs 13 14th December 2007 02:42 PM
Transformer Rating sushi Pass Labs 12 15th August 2007 04:05 PM
Transformer VA rating?? RyanW Power Supplies 6 11th November 2006 10:23 PM
Transformer VA Rating vs. Current Rating JhonDoe Chip Amps 45 5th June 2004 01:11 AM
Page generated in 0.08470 seconds (67.91% PHP - 32.09% MySQL) with 10 queries
