| Home | Forums | Articles | Gallery | Blogs | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
| Chip Amps Amplifiers based on integrated circuits |
Thread Tools |
I've got an E core transformer from an old amplifier just sitting around (its in good condition) and was thinking I could use it to build a Gainclone. The amplifier was rated for 230watts power input so I figure that the transformer is large enough to power a gainclone. The only problem I see is that its secondaries voltage is around 30vac. After rectification and filtering, thats around 42 volts + and -42. Is that too high for the IC? If so, what (preferably easy
) methods are there to get the voltage back down to an acceptable level? I plan on driving 2 8ohm compression drivers with the amplifier, so it will rarely be pushed to max output levels.Thanks! |
#2 |
42Vdc is max allowed on LM3886, so this is fine. Using a regulator like the LM338 can bring down your usable Vdc to the 3886 to about 37Vdc.
#3 |
Well in another thread it says 42v is too high. So, what ways can I get the voltage down, if any?
#4 |
42 volts is fine. Im using that voltage and liked the sound of my VBIGC. Just make sure your heat sinks are sufficient.
regards, will. |
#5 | |
I also run 42V... no problems in the 4 years since i built it. |
#6 |
42Vdc will be quite too high if you intend to load it with a speaker lower than 8 ohms. However, as I said, if you want to lower it, for whatever reason it may serve you, you may use an LM338 regulator, and it can give you 32Vdc highest.
#7 |
my txs' secondaries are also 30VAC - i posted a psu schem in this thread: regulated psu for gc yesterday which -I think- is okay...
hth |
#8 | |
Electrons are yellow
Note also if you have no input signal the max voltage is 94 volts (2 x 47) so if you play a little the voltage probably will drop a bit. If you had a toroid transformer the max voltage would have been 2 x 30 VAC. The normal max voltage is 2 x 28 VAC.
/Per-Anders (my first name) or P-A as my friends call me BPA300 Group Buy Round 4, SMD-kit and DRV134 pcb. Not too late to sign up. Sign up HERE |
| Thread Tools | |
| This toriod suitable for gainclone | joka22 | Chip Amps | 13 | 1st August 2008 10:12 PM |
| Suitable transformer | mantisory | Solid State | 8 | 7th February 2008 04:56 PM |
| NAD3130 heatsink suitable for gainclone ? | ash_dac | Chip Amps | 1 | 12th June 2006 07:41 PM |
| WTB gainclone-suitable (18-0-18 to 25-0-25) transformers, MUR860's,soldering station. | Spasticteapot | Swap Meet | 4 | 20th March 2006 05:22 PM |
| Looking for Amp project suitable for a 35V Transformer | ptrapp | Solid State | 11 | 2nd October 2001 05:28 PM |
| Page generated in 0.08811307 seconds (85.45% PHP - 14.55% MySQL) with 10 queries |
