| Chip Amps Amplifiers based on integrated circuits |
I was reading Idefixes thread, and wanted to design a gainclone pcb that is single sided and easy to make at home. This is my first attempt at a pcb layout, so will someone please critique it? It's based on Briangt's schematic. Thanks!
BTW there will be a 22K resistor between pins 3 and 8. |
#2 |
Location: Where the rain does fall but the trees grow tall
mateo88,
It looks like you meant to attach a image. But I don't see it. Was it too large by chance? |
#3 |
you mean like this:
http://www.tech-diy.com/lm3875_board.jpg |
#4 |
Yes, I did intend on attatching an image...
#5 |
That Tech/DIY PCB leaves alot to be desired. With the chip mounted so far in from the edge, how does one ever hope to mount it in a clean fashion? Look at how spread out the parts are, with sharp acute bends...a no-no in PCB design.
Just so room for improvement is all I am saying. -Matt |
#6 |
Hmmmm.... Perhaps because I am still "under moderation" the images will not be attatched. When I clicked "view contents of this post," however, the attatchment showed up. I'm not really sure what's going on, but the image is only 48k or so.
#7 | |
the bends aren't "acute" -- If you have a Gerber viewer, take a look at the Gerber files on Nat Semi's "Overture" design page. (the image below is an X-Ray of the LM4730 board which illustrates how National's engineers layed out the board for their 18W stereo chip) even if you hard-wired the resistors directly to the chip you wouldn't be able to get them any closer to the pins of the LM3875 -- and I have tried! I am using 6 of these boards right now. i had no trouble mounting them on an 11 inch Thermalloy extrusion with a (quiet) 200 cfm blower. |
#8 | |
#9 |
mateo88 :
what is that wire between the connectors of C1? is that the input signal ? imho u should put it somewhere else ps whats up with those resistors connected directly to the chip ? c'mon guys +-1cm wont do any difference |
#10 |
oh thats the out
well i think it should be thicker and i still dont like the location |
| Single sided PCB for Zen v4 | kirc | Pass Labs | 59 | 3rd May 2012 11:29 AM |
| X-over for single sided tweeter. | Jonathan Bright | Planars & Exotics | 4 | 2nd June 2008 07:44 PM |
| Single sided GC | DragonMaster | Chip Amps | 16 | 9th April 2006 08:50 PM |
| 50 watts more, single sided? | psychosteve | Chip Amps | 4 | 14th September 2004 04:35 PM |
| Single Sided PCB for Zen V4 | GeorgeBoles | Pass Labs | 0 | 29th August 2004 12:55 AM |
| Page generated in 0.14641 seconds (63.91% PHP - 36.09% MySQL) with 11 queries |
