| Chip Amps Amplifiers based on integrated circuits |
Hi...
I'm designing the psu brd for the gc amp I'm planning and came up with this based on a circuit at pedjas' site...(PDF) GC PSU The +/-24V is for the lm3886's and the +/-15V for some INA134 balanced line receivers.... Does it look okay? Thanks. |
#2 |
Looks fine to me . Why not place the 15v regs on the un- regulated dc lines. That way you can put a variety of regs with different voltages, without up setting the regulator before it..as per the current arrangement.. 24v adj supplying 15v fixed
Just a thought..
#3 |
Hi...
Thanks for the reply... I've just realised tho - the secondary on the tx is 30VAC - wont that mean then it'd be like 40+VDC hitting the vregs - the 7815/7915s are just not gonna have that..are they? Even 24V at input is too large no? mebbe a 2nd smaller tx just for the INA's would be better suited? Cheers |
#4 | |
#5 |
Hi Pedja...
Yup, thats what i thought - but is 24V into the 78's ok? Isnt the max input V for 'em rated at 17.5V? I have the transformer already (2 infact) and will be runnin 2 channels of a single lm3886 design into 4ohm speakers from it... Best |
#6 |
No, why 17.5V? Max input voltage for fixed 3-pin regulators is usualy 35V, and 40V for 7824. Though in some cases it is lower for negative regs. Simplest, check the corresponding datasheet.
#7 |
was looking at the wrong table ;p
time to build
#8 |
| Regulated or non-regulated SMPS | longitude | Class D | 5 | 8th May 2007 04:02 PM |
| Need a little help with my first regulated PSU | jarros | Power Supplies | 16 | 3rd May 2005 12:28 AM |
| Regulated PS Kit | cantskienuf | Chip Amps | 7 | 24th September 2004 04:20 AM |
| Regulated PSU Help.. | jleaman | Analogue Source | 9 | 26th July 2004 01:36 PM |
| Regulated or no regulated PSU? | Higo | Chip Amps | 2 | 16th July 2003 05:38 PM |
| Page generated in 0.09073 seconds (79.67% PHP - 20.33% MySQL) with 10 queries |
