| Chip Amps Amplifiers based on integrated circuits |
Here's a 4 channel amp I made with Brian's boards. I used 1/4in Aluminum for the inside, top and bottom plates, 1/2in Al for the front and back, and white oak for the side. It has a cute matching preamp, done in a smaller scale.
#2 |
The view of the bottom when flipped.
#3 |
With the matching preamp.
#4 |
Each side has its own transformer and power cord. They power two two-way speakers, each driver on its own channel. The sound is very good, detailed and spacious.
There is a slight hum that you can hear next to the speakers, but you can't hear it while playing music. Still, I worked hard to get rid of it. I insulated the signal cables, and added an aluminum plate as shield between the diodes and the chips. Each side has its own star ground and they don't touch each other. I tried a single star and it didn't matter. Might be the transformers, or the fact that I'm using Avel 25V 300VA instead of my usual plitron 20V 300VA. I should mention that my speaker drivers are really sensitive (~100db) so this might be normal. |
#5 |
Very nice work! That's one solid case!
I working on something similar to that right now...hopefully it turns out as nicely as yours did
gravity always wins |
#6 |
Detail of one channel.
| Creating 5.1 Multi Channel sound from 2 channel | jenkrich | Everything Else | 5 | 1st September 2009 07:29 AM |
| 4 channel conversion to mono 1 channel | iUSERTLO72p | Car Audio | 24 | 25th October 2007 05:07 PM |
| HELP!: Channel volume very very low, other channel fine. | harrisni | Solid State | 2 | 20th September 2006 11:10 AM |
| My 4 channel car Amp distorting on 1 channel (large pics) | MikeHunt79 | Car Audio | 9 | 3rd September 2003 06:41 AM |
| Help quick! 4 Channel > 2 Channel? | zmoz | Car Audio | 3 | 5th July 2003 08:48 PM |
| Page generated in 0.09201 seconds (73.54% PHP - 26.46% MySQL) with 11 queries |
