| Chip Amps Amplifiers based on integrated circuits |
Hi all! I made a kooky mistake and didn't read before i bought a sub amp. it was this one.. http://www.allelectronics.com/cgi-bi...A-6&type=store
I thought i was getting a good deal and i may have if only i could get a little help. The amp has speaker level inputs, and i was going to use my line out from my reciever to power some bass shakers in my couch. well dumb me didn't read carefully as the amp has no line in. I am somewhat electronics competent but surely no engineer. I was told to look for a resistor dividor and try to bypass it, there were several pairs of resistors of varying ohmage. so here is what i did, i took a cheap speaker and hooked it up to the output of the amp, then i ran my line level (sub) to two wires. (I measured the output of the reciever and it is in the area of .03 volts during semi-loud passages) I took those two wires and started poking around the bottom of the first circuit board (the small one with the level knob and the xover freq pot) well after many loud pops I found 2 spots that work...... one of them makes the actual subwoofer go quiet while all juice is diverted to the crappy speaker, and the other spot sure gets good reception of some AM radio station. plleeaaaassee help me, ask any questions of me about this that i may not have said clearly. If i had a schematic i could have done this in 5 minutes, as it is i spent 3 hours poking around in spots after the initial resistors in the circuit. thanks much. Mike I also forgot to mention that in the spot where the radio station came in, the speaker would not go as loud as in the other sub killing position. |
#2 |
aren't the speaker level inputs the "line-in" of the amp? and one of the wires at the back is connected to the speakers/bass shakers?
forever dreaming of a better set-up... |
#3 |
I guess they are the "line-in" but the line in is at speaker level, which is however many watts it can take. It uses a resistor dividor (i believe) to scale down the voltage and it sends that signal to another amplifier. wierd me thinks. but the subwoofer line level voltage out of my reciever is .03 volts'ish. and the output of the amplifier is connected to a speaker so i can hear if the circuit is working. so far i have found 2 spots after the divider that work, but one gives me an AM radio station as well as the bass signal, and the other spot steals the signal from my main subwoofer. it is strange. I need help from a whiz kid here...... why would it recieve am radio? why does it steal the signal? those are my Q's
Mike |
#4 |
Probably the easiest thing to do is take a feed from your
subwoofers bass driver / amplifier output and feed this into the shaker amplifiers high level inputs. I'd fit a 100R series resistor to this feed, if the frequency control on the shakers amplifier does not go low enough fit a capacitor across the shaker amplifiers inputs (after the 100R series resistor) for further bass shaping. Its also possible the shaker amplifier will accept a line level input directly to the volume control on the board, here you need to disconnect the attenuator network feeding the volume control (if the circuit is arranged this way, it may be, it may not be). sreten.
#5 |
Wouldn't it be easier to amplify the line level you want to use?
If you build a very small-easy circuit with a cheap IC (e.g. LM386 from National) you can get what you want without touching your amp. |
#6 |
frugal-phile(tm)
If you start at the speaker level inputs and trace the circuit from there, it should be pretty easy to figure out where to install a set of input jacks. There should be a cap between those and any satelitte outs... following the other path there should be a series R for each channel, then they should sum togther... that is the 1st spot to consider. There may be a little more passive circuitry before you get to the 1st active stage, some will be needed, some may not.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#7 |
I have a passive preamp with 10 kohm DACT stepped attenuator.
http://kotiweb.kotiportti.fi/audiovideo/DIY/preamp1 Is it ok to use passive preamp with Gainclone or should I expect some problems? I'm going to use TDA7294 DIY kit: http://www.tricomp.fi/tuote2.php?id=...nrakennussarja |
| Page generated in 0.11787 seconds (71.22% PHP - 28.78% MySQL) with 9 queries |
