| Chip Amps Amplifiers based on integrated circuits |
I've been looking all around (in Dehli) for a TDA 7294 IC. Can some guide me.
Thanks |
#2 |
better go for lm3876 , they are more reliable and availability is good almost anywhere, belive me i had a very bad experience with tda7294.
thanks bye arasu
thanks a many for the diy audio for its existence. |
#3 |
Thanks Arasuk.
Can you let me know the price of lm3876 INR? And some one, please confirm if this is available in LajpatRai Mkt in Delhi. |
#4 |
hi ,
lm3876 should cost about INR 100-120/- max. and i belive these should available at your place , with more of searching and enquiring probably you will be able to get it. all the best. thanks bye. arasu
#5 |
Thanks again.
Been going through the data sheet for lm3876. Have you built an amp around an lm3876? What supply voltage did you use? What should be the ideal supply voltage for this chip? Also, please mention the current in Amps |
#6 |
hi there,
yep I have done this amp and belive me this amp is really more reliable than TDA7294 , I had 3 of those tda7294 all of them just blew as soon as the power supply was provided, For Lm3876 you can go ahead providing +/- 30volts, 3amps. don't exceed +/- 35 volts for long run purpose & above suggested values would be best and this amp is really Rugged in terms reliability. thanks arasuk
#7 | |
Yes I have used those chips as well. They are good for the price but (with expensive components) are not better than the mini crescendo. But the TDA has usefull features that the LM does not.
#8 |
Hi!
If I remember correctly same TDA family is used in Creative PC speakers. Not bad for the price. Regards Rahul
We can make it work |
#9 |
i wonder where u went.u left shop no 401,245,396 and so many others.go man go.
#10 |
greetings everybody!
since this thread is somewhat also related to general availability of chips in Delhi, I would request anybody who has idea about availability of TDA1524 (for bass and treble control) and LM1036(An alternate, also for bass and treble control) to please post here. I have found out from all the shops like 614,403 etc that my friends had recommended. Also I was planning to use 4 ohm car speakers (the oval ones that are available in quite a lot of shops in Lajpat Rai) enclosed in a speaker enclosure (Like the ones available in 509). Any suggestions / past experiences ? I would also like to put up my query regarding power supply here...I am using an 18-0-18 transformer which after rectification and all gives me about 26-27 volts dc to drive my lm3886 amplifier into a 4 ohms load. I put a multimeter in series in one of the "18" output terminal of the transformer(which is giving me 18-0-18) and note that current consumption is about 1.5 amperes. My doubt is that what is my amplifier actually consuming? 1.5A or 3A? Thanks |
| [INDIA] Any DIYer made a Gainclone in India. willing to help? | smarcher | Chip Amps | 62 | 2nd April 2009 05:05 AM |
| need to get frm DELHI,two electronics projects-be kind to guide | mobileman | Parts | 0 | 20th July 2008 01:04 PM |
| Parts in Delhi | ssmith | Parts | 10 | 9th March 2007 09:28 AM |
| d-amp availablity, pricing, support | raintalk | Class D | 1 | 31st May 2006 01:46 PM |
| Hi From New Delhi | s_zimble | Introductions | 18 | 31st October 2005 04:23 AM |
| Page generated in 0.14662 seconds (66.07% PHP - 33.93% MySQL) with 10 queries |
