Old 23rd June 2004, 09:47 PM   #1
Franz G is offline Franz G  Switzerland
Franz G's Avatar
Default What chip for 2 x 60 V?
I have a big main transformer, out of an Fostex PA-amp.
Without load, I measured 2x60V and on a second secondary 2x16V.
Any idea to build a great amp around this stuff?
Franz
http://mypage.bluewin.ch/gysiaudiophil/fostextrafo.JPG
Old 23rd June 2004, 09:57 PM   #2
Send a message via MSN to officeboy
That main seconday is way to large for anything in here. 30Vac secondaries are about the tops for National chip amps at least.
Old 24th June 2004, 01:16 AM   #3
Banned
you have to go discrete and build a real amp.
http://www.passdiy.com/amps.htm
Old 24th June 2004, 01:52 AM   #4
ashok's Avatar
Default High Voltage chips.
Have you checked LM4780 ?
Supply Range ± 20 - ± 84 V
It's on National's web site. I didn't look at it closely but if it does go that high it might not have enough current handling capability for your application. Add some external power devices.
Ashok.
AM
Old 24th June 2004, 02:06 AM   #5
moving_electron's Avatar
Location: Where the rain does fall but the trees grow tall
Another solid state discrete possibility. Can take up to a 70v supply.
ESP P101
Old 24th June 2004, 11:46 AM   #6
djk is online now djk
djk's Avatar
"Have you checked LM4780 ?
It's on National's web site."
That is an error, it should read 84V total swing, or ±42V.
A 2X 60V transformer will give ±85V rectified and filtered. This is consistent with the pair of 18,000µF 100V filter caps in the photo. The filter caps are big enough for a two channel amp running on 50hz (or higher) driving a 4 ohm load (or higher) per channel.
My guess is that with typical construction what you have would give 250W X 2 at 8 ohms and about 400W X 2 at 4 ohms, with about 3dB of dynamic headroom.
The dual 16V windings are intended to drive opamps, relay circuits, etc. They would normally be rectified, filtered and then regulated to ±15V.
I could recommend a circuit if I knew the intended use.
Old 24th June 2004, 12:10 PM   #7
Franz G's Avatar
Default no project yet
Your guess is perfect: this is an transformer, out of an Fostex 2x350W amp!
Actually, I have no big intention or special application for such high power, specially not with my Coral Beta 8 Speakers, normally driven by my 300B SET.
So I think, I will put this transformer in my box, for a later project.
Many thanks!
Franz
P.S.
The power from the chipclones is already to high to try them with the Corals. To much risk for this gems.
Old 24th June 2004, 12:24 PM   #8
Circlotron's Avatar
Thumbs up Choke-input filter.
If you use a choke-input filter, once you have more than a certain minimum load, the dc voltage will sit at 0.9x the transformer voltage, i.e. +/- 54vdc. At zero load it will go up to the peak voltage though, so some kind of preloading is necessary for anything other than a class A amp.
Best-ever T/S parameter spreadsheet.
http://www.diyaudio.com/forums/multi...tml#post353269
Which Chip AMP you like most? dynabok Chip Amps 43 30th September 2008 08:55 PM
Pre-amp for chip amp wotsascott Chip Amps 23 30th April 2006 04:24 PM
First Chip Amp doomsweek Chip Amps 9 10th May 2005 01:55 AM
Best possible 10W from chip amp Robert_66 Chip Amps 14 2nd November 2004 11:43 AM
Hot chip! batkey Chip Amps 1 14th October 2004 11:54 AM
Page generated in 0.09421 seconds (78.55% PHP - 21.45% MySQL) with 10 queries
