Old 23rd June 2004, 12:16 PM   #1
LilMik is offline LilMik  Germany
Question LilMiks opa549 GC
Hello,
my first post .
i am michael from germany and i am 14 years (well, alsmost 14 years ) old and my english is
really bad .
i want to build a gainclone with the opa549 chip. i did read a lot of threads. so it is
a basic nigc that i want to build. the gain is 21. i want to use a 25k pot.
i think i can leave the pin 9, it is the e/s pin, open.
i am not sure about pin 6 and pin 9, it is the ref and the Ilim pin. according to figure 1
in the opa549 datasheet (you can find it on page 8), i simply have to connect both pins to ground. right?
i hope that you can see my schematic.
lilmik
Old 24th June 2004, 11:12 AM   #2
matjans is offline matjans  Netherlands
matjans's Avatar
Send a message via MSN to matjans
depending on your psu i would bypass the 4700uF caps with some smaller ones.
Old 25th June 2004, 03:17 PM   #3
miguel2 is offline miguel2  Portugal
If you use the inverting circuit you can use a SMD resistor in the feedback loop - quite easy to solder. I have this configuration with 220K. Input is 10K.
I am working now on a discrete regulated PSU for it, as described in Pedja's site, to see how it works. But 1000uF on each rail will do.
Ground the 6 and 9 pins to get it working.
Miguel
Old 29th June 2004, 11:33 AM   #4
hello,
thank you both.
i don't know for sure what cap's i am going to use. i will
order a few diffrent caps, resistors, ic's (:cry: ns don't like me, they don't want
to send me free samples... but ti does like me ...) and so on with diffrent values
from www.schuro.de.
for sure i will try the igc, with and without buffer and so on .
lot's of stuff to play with .
have fun
lilmik
Opa549 Treefingers Chip Amps 1 23rd September 2005 08:37 PM
Fs: Opa549 bigmike216 Swap Meet 3 26th August 2005 12:08 AM
OPA549 GC for Car abid_rehan Chip Amps 11 13th June 2005 04:09 PM
Opa549 ctardi Chip Amps 6 8th May 2005 07:43 PM
Page generated in 0.07767 seconds (72.73% PHP - 27.27% MySQL) with 11 queries
